C
Chrusty 1
Thats OK. Knew all that stuff from 30+ years ago would come in handy one day (or not!) Just don't get me started on pre 1965 Fordson tractors.
I promise you, I wont!
Not quite correct. There were (for most of production) two powerheads and 3 gearboxes.
So, the only choice in prop was between the fan type and the weedless as the two were interchangeable on the same model. There was minimal difference in performance.
I also have a vintage barge-pusher with 13" prop
Want to test it on the folkboat when i finally get it in the water!
--------------------------------So that might have happened from trying to start it in the mud, but not from pulling too great a load?
At the point at which the help came, it felt almost the compression had tripled - that is, it would still turn by the starter cord, but only with huge effort and no where near enough to start.
Spring? Mud caught in somewhere..?
A Seagull is nothing like a Mini - the latter was rubbish from the very start.
Nothing wrong with Seagulls if you recognise what they are and treat them right.
The Short shaft Seagull serves its purpose to move the 16ft Punt around the Pill Moorings as there is usually more than one person on board.
Spare spring fitted yesterday.
A long shaft would have been better suited on this occasion!
Nice to note you were still smiling when we started to strip your faulty outboard.![]()
Of course one of the reasons most Seagulls are so bl##dy noisy is that they have holes in their exhaust tubes !Don't forget your ear defenders!![]()
Luckily the 102 series have water-injected exhausts, and thus run somewhat quieter without those exhaust vent holes (which actually aren't necessary, despite what British Seagull has frequently said over the years).
The other BIG source of noise of course being the carb intake - haven't seen any really good solutions to fix that one - c'mon chaps - thinking caps on ...
Quite right too ...But I like the sound - it is distinctive & instantly recognisable, SWMBO knows I am coming back. Why would I want to sound like all the other tenders & generators on a bank holiday?
Agreed. Your should always be properly attired for sailing. Take a look at the illustrations of Joshua Slocum in 'sailing alone around the world'. (The fount of all knowledge) - don't forget your tie and waistcoat.Fascinating.
Having served my apprenticeship with Seagulls and ended up with a Yamaha Malta I know the vagaries of most outboards. If you want a Seagull ....go ahead but you have to embrace the problems of running vintage machinery.
So, drive down to the dock in your Austin 7, hitch up your plus fours and step aboard your clinker dinghy , fire up the Seagull and off you go!!!!
