BabaYaga
You are totally wrong, batteries are useless as anchors.It seems batteries are the new anchors....
Lifeline AGM ... very nice.
Remind me again how much each battery costs?
Was it 3x or 4x the cost of a regular leisure battery?
As catergories, 'starter batteries' and 'leisure batteries' are not identical. They have different properties.
Who says so? You do.
But it wasn't required to deliver any starting amps, or do much in the way of deep discharge high capacity......
As an aside, i had a customer who had a Honda 70. It was little used, a 6V model, I MOT'ed it every year for a long time.
It was over twenty years old and the OE Yuasa was still giving good service.
A leisure battery is a starter battery. It has some additional plate support etc and is suitable as an engine starting battery on a boat and for domestic use too. It is not a deep cycle battery ( no matter what the label might say and no matter what the advert says) and it most certainly isn't a starter battery and a deep cycle battery in one package.
And 4 wheels, and boats and now the space station.Yuasa is usually a good choice for anything with two wheels
Great stuff.
So back to the original question, you have a boat that has two batteries that start an engine and that also have to act as a domestic power source.
Do you buy batteries optimised for starting, leisure batteries, or fancy AGM batteries that are 3x the cost?
A cheap and nasty car battery is a starter battery., a calcium SLA battery is a starter battery, an ECM battery is a starter battery, an AGM stop/start battery is a starter battery, and a leisure battery is also a starter battery. They are all starter batteries, but they are clearly all different in some way or another. The cheap and nasty car battery might only have 2 or 3 cycles at deep discharge, a quality AGM will be totally different.
OK, getting a bit clearer now.
Unlike in January, when apparently 'starter battery' = 'cheap and nasty car battery', you are now using 'starter battery' as some kind of meta category for several types of batteries.
More confusing than helpful, IMHO.
Your main point seems to be that deep cycle batteries are something different from those mentioned in the quote above. But I can not see that anyone has challenged this, I certainly have not.
Please stop going on splitting hairs - its painful....... and is everything I dont like about YBWOK, getting a bit clearer now.
I would put 2 of the same, so running in parallel whist charging is relatively equal. Therefore it would be a pair of batteries with a less CAA and more capable of 50% cycles..... Perhaps the weight of the battery will tell you which would be more suitable (heavier = best?) other than the rubbish printed on the wholesalers sites!Great stuff.
There is no such thing as a hybrid battery, in as much as it cannot be one of the above and a deep cycle in one package.
There is no such thing as a dual purpose battery, in as much as it cannot be one of the above and a deep cycle in one package.
I used to ask people who were looking for a "marine battery if they wanted a car start, lorry start or deep cycle "marine" battery. I used to see lots of "leisure batteries" which were actually lorry start batteries.If you are unable to understand, perhaps you should go somewhere and learn. Everyone else in the thread seems to have grasped it.
Personally, i'm not wasting any more time with your trolling posts.
Interestingly, maybe, I mistakenly purchased T105 Dual Purpose batteries from a popular online retailer, thinking that were Deep Cycle, as that was the way they were advertised, I spoke with an engineer from Trojan in the US, they explained that the Dual Purpose would only have a life expectancy a third of that of a truly Deep Cycle battery, when used in a leisure bank discharging down to 50% at times. I got this in writing from Trojan, and after some debate the online retailer agreed I could return at their cost, and then replace with true Deep Cycle batteries.
I read the recent threads on battery replacement and remain a bit confused on one point.
One contributor, whom I respect and who seems to know his stuff, says there is no such thing as a hybrid battery, it is either a starter battery or leisure battery. He also identifies Hankook dual purpose batteries as good value.
So, what is the difference between a hybrid battery and a dual purpose one?
