ChrisE
Finally did this last night and I was generally impressed with the thought that has gone into the system. A couple of things came up that I thought were worthy of further dissemination.
1. Distance of a sighted parachute flare. I'm sure that the old salts around here know this but as I'd not heard before here it is. Max range you can see a flare (all designed to go up 1000' and burn for 45 secs) from a yot is about 26 miles and then it will appear breifly on the horizon, ie it is horizontal to you. If you set off a flare on your craft it will be stringht up from you ie at 90 degrees. From these two sides of triangle you can work out how far the flare is away from you. So if you see one at max elevation of 45 degrees it is about 10-13 miles off, 30 degrees nearer 16, etc.
2. SARTs, these seem to me be really useful things to have in the liferaft. I like the idea of a pointer on a big ships radar showing where I am. Off to buy one this weekend.
One last odd point, you can send off a DSC piracy Mayday automatically that gives your position, just what another pirate might want to join in the fun, I thought. I suppose that you could disconnect the GPS but then the rescuers wouldn't know where you were either!
