prv
Blast your fire quickly with what you have, and more importantly, GET OUT
Where to?
What you seem to be overlooking in urging the purity of your argument iss that in any fire the rush of air will introduce breathables and diminish the concentration of CO2 around the operator to likely bearable strength.
If anyone reading your contribution is persuaded to stick with powder cylinders you will have done no one any good whatever, however satisfied you might feel about your references.
PWG
lets not discus spherical heating. those CO2 ppm are a bit weird, i mean, the breath you exhale is 5% CO2. so no rebreathing air in a paper bag when having a panic attack. and none of that breathing in while french kissingRe CO and CO2
For what it is worth
the long term and short term occupational exposure limits for carbon monoxide are 30ppm and 200ppm respectively.
The limits for carbon dioxide are 5000ppm and 15000ppm. ( 0.5 and 1.5% !)
Those figures would seem to indicate that CO is considered to be far more dangerous than CO2
The concentration of CO2 in the earth's atmosphere is greater than even the short term OEL for CO
Not for 8 hours, no!those CO2 ppm are a bit weird, i mean, the breath you exhale is 5% CO2. so no rebreathing air in a paper bag when having a panic attack.
Old Harry,
Do you have any info on the 'new chemical ext.' that was recommended?
John G
There is a liquid phase at very high pressures. The CO2 in presurised bottles must be in solid form though.
Halon was stopped ( EXCEPT Military Use ) as its a so call greenhouse gas & for no other reason
.....If you get a blocked up nose ........, stroking pussy ....
It was phased out because, like all CFCs, it causes immense damage to the ozone layer. That's a completely different issue.
Frankly, compared with death, I'd rather clean up some powder in my boat (and NaHCO3) is water soluble).
