Ian_Edwards
I've read the advice on drilling SS posted on the forum and followed it. Using a drill press with a sharp drill bit, low speed, lots of axial force and well lubricated.
I bought two lots of SS from different suppliers, a sheet of 6mm x 270mm x 250mm and a length of 6mm x 25mm flat bar.
I've successfully drilled the sheet material, starting with a 3mm pilot hole and then opening out to 8mm. The swarf came off in a nice continuous spiral and the process was relatively quick .... no problem.
However, drilling the flat bar is much more difficult, using exactly the same technique, the swarf comes off in chips and the drill bit chatters, progress is slow and the drill bits get damaged. It looks like chips are breaking off the cutting edge of the drill bit.
The drill bits are 4% cobalt and I keep them sharp by re-grinding them. I can take a drill bit that works well on the plate and it struggles on the flat bar.
I guess they are different grades of 316 and the flat bar may be work hardened.
I've got about 25 holes to drill in the flat bar, is there anything I can do to make life easier?
Would annealing the flat bar work? And to do that, would I heat it to cheery red and then allow it to cool slowly? Like I do for mild steel. Would that make the SS more prone to corrosion?
Is the a better type of drill bit I could buy, which would cut the through the flat bar?
Or anything else??
Or anything else??
