snowleopard
Now watch it in action (skip to 1:40 to avoid silly preamble).Moving the ruler to the right against the roller will not drive the cart to the right.....So it will accelerate to the left.
The road is the source of energy, and you use it to do work on the wind.
It's getting confusing switching between threads. I'm beginning to regret starting the second one.
I think I can answer that question. Look at this mechanism....
The cart moves around 3 times as fast as the ruler above it. Now replace the upper wheel rolling along the ruler with a prop moving through the air - just another linkage but this time with an inefficient coupling.
We won't get 3x speed of course because of prop slip but with a good prop we will get more than 1x.
The ruler thing is a complete red herring
I can't access u-tube here, sorry.
Super Geek and the Snow Cat are trolling, and doing a very good job of it. They are moving the goalposts as they please, mixing theories.
Please don't feed the trolls.
For those who have closed their minds to the possibility they may be wrong there can be no understanding. I started out a cynic but I sat down, analysed what was going on and understood it.
Just don't get into any heavier-than-air machines, stick to balloons if you want to fly.
Firstly please do me a favour and desist from claiming that one grainy video on youtube "proves" this, or another grainy video "refutes" that. I have seen the inside of the Tardis on youtube, but that don't make it so. Proof is a very big thing, and it doesn't look like the videos you post. It looks like hundreds or thousands of repeated experiments, with very accurate measurements demonstrating a statistically significant effect. Which is then repeated by completely independent experimenters, not once but many times. And finally is subjected to independent peer review and published in a reputed journal. There is a good reason why people study for years to earn a Phd, and why you cannot download Nobel prizes online.
you are out of sensible arguments.
Well done. You stuck it out a lot longer than I did.It's pointless trying to debate with someone who sticks their fingers in their ears and shouts LA LA LA. That's what this has become. I won't bother any more.
That works and here is the film of it in action. (skip the 1st 1min 40 secs). That shows a mechanism that uses the relative movement of two surfaces to produce motion faster than the original.
Now replace the ruler and wheel with air and prop. The coupling is a lot less efficient but it does the same job.
NO!
the road does not accelerate, change state or temperature, except perhaps a little frictional warming...
It does not give up any energy to anything else.
