RAI
Tack/Gybe -A moot point, since the apparent wind for these boats stays ahead of the beam.The boats are so efficent they can bear away significantly and the apparent wind is still forward of the beam. At some point, however, the boat is travelling too far downwind and there is not enough wind from the side in order to drive the boat. Imagine the boat travelling at 20 knots on a broad reach in 6 knots of wind. There is still some (true) wind coming over the side of the boat. The speed of the boat will bring that apparent wind well forward of the beam. But if the boat bears away to DDW, the vectors simply cancel each other out. The boat is now, in effect, head to (apparent) wind, and can't sail. Just as there is an optimum tacking angle upwind, for these boats there is an optimal gybing angle downwind (they don't tack downwind, they gybe downwind).
Are the propeller blades on this machine going dead down wind, even if their axle is?These boats do NOT use the mechanism on which the DDW advocates rely - which is going straight DW, and extracting energy from the kinetic energy of the vessel and impart it into the air to produce thrust.
