Tamar
Could I use these on my fuel filter bleed nut? It's says you can use with fuel but it doesn't say which fuel,m
The bottom washer is on the threads I guessIs the washer clear of the threads on the bango bolt? Are the surfaces of the bolt and filter clean and smooth?
Whenever I had this it was always a slightly challenged primary filter, but expect you have checked that already. Engine dipped for a few seconds then recovered...It's much better than it was. At sea the engine would suddenly lose about 100rpm for a few seconds and sound choked then surge back up to speed. Always when fully loaded with around 10 people. Yesterday it was fine although when I checked the Banjo it was slightly wet
Yes I put new filters on. Just can't get a good seal on the Banjo fitting on the secondary fitting.Whenever I had this it was always a slightly challenged primary filter, but expect you have checked that already. Engine dipped for a few seconds then recovered...
