25931
It must be forty years since I last sailed without VHF. Does anyone do so today ?
It is in Portugal where a vhf is legally required.Well, I usually have it switched off unless I need to call someone, so I guess that's no different to not having one really.
That is an interesting comment ? Where do you sail ?Well, I usually have it switched off unless I need to call someone, so I guess that's no different to not having one really.
Sorry, my question was aimed at BobC, who does not mention, where he is based ?As above, ours is mostly off/the volume tuned right down unless no internet reception and awaiting a weather forecast.
He sails around Portugal.That is an interesting comment ? Where do you sail ?
I c now bobHaving got a VHF set on board I feel I should have it on in case I am ever in a position to help someone in difficulty or distress.
I would never forgive myself if someone did need help and I had done nothing.
BUT I sail exclusively on the French Atlantic coast and there is little VHF traffic, and none of that endless maddening babble of "Radio check, please" that is such a nuisance in the Solent. I could sympathise with anyone there who felt like tearing his VHF off its bracket and hurling it into the sea.
Someone told me if you are licensed to have a vhf you are required by law to have it on,maybe wrong,long time ago.Having got a VHF set on board I feel I should have it on in case I am ever in a position to help someone in difficulty or distress.
Was that the boat licence or the operators ?Someone told me if you are licensed to have a vhf you are required by law to have it on,maybe wrong,long time ago.
I have a VHF and normally keep it turned off when in the vicinity of the Solent. Not irresponsible or even bad seamanship. Those abusing the VHF are the ones being irresponsible and showing bad seamanship as too many boats doing constant radio checks and calling each other up on 16. As I move away from the Solent I start to turn the VHF on but possibly go to a working channel such as used by Lulworth firing range. Further West or south I normally listen on 16 as there is much less chatter.In my opinion it's an essential piece of safety equipment for both yourself and for others.
If you sail without one then you put your own life and potentially the life of others at risk.
If you have one and deliberately have it turned off then that is even worse. Of course you can turn it on if you need it but you won't hear any distress calls from others and therefore be unable to respond.
Irresponsible and poor seamanship.
I recently completed an "emergency seminar" at Fremantle Sailing Club, Western Australia. I was astonished to lean that the majority of boat owners have never heard of DSC and on digging deeper this is because they use 27MHz and not VHF.
I find this astonishing. I couldn't find ANY boat owners who had a radio operators license, even the club official running the seminar!
It is even more surprising because it it pretty much mandatory to log in with either your own sailing club or Sea Rescue (equivalent of RNLI) before leaving your marina.
However it must be said that the vast majority of boat owners never go further than Rottnest, about 10 miles offshore, although the swell off the west end does get pretty big.
Personally I keep my VHF on 16. The main radio set is below decks with a cockpit repeater and a wireless handheld to control it. I am alarmed by the number of incidents (in the Solent and South Coast). I have been closest vessel (by distance but not time) to two Maydays however both were responded to by better equipped (and faster) vessels. Before I had AIS I have used VHF to call commercial ships to advise them of my intentions. And I don't think I'd want to sail past Europoort without VHF and AIS.
I reckon it comes under, " keeping a lookout" so I would definitely ask WHY you are under way with the VHF turned off.Someone told me if you are licensed to have a vhf you are required by law to have it on,maybe wrong,long time ago.
