garymalmgren
Hi Double Ender
You have 6 choices. (Maybe more that I haven't covered)
1, Don't buy the boat.
2. Buy the boat and new engine.
3. Buy the boat and used engine.
4. Buy the boat and have the engine professionally rebuilt.
5. Buy the boat and repair the non-starting fault.
6. Buy the boat and rebuild the engine yourself.
If you decide to buy the boat you are dealing with
But... the boat has been ashore for 2 years and the 1GM10 has not been run. Now it won't start.
The causes for non starting are usually fuel or compression related.
You mention;
The low intervention problems have all been investigated, up to and including new injector nozzle.
Personally, I would have the head off before going for new a new nozzle.
I am not criticizing whoever took that route, just pointing out what I see.
I would go you option 5 and then (if unsuccessful) to option 6.
Even if you do not have a deep knowledge or experience with diesel (or any engine) this is a good time and place to start.
I feel for safety and a sense of security familiarity with your engine is a must.
An experienced and reputable engineer now says there is little compression, & the engine needs removal, head and sump off, piston rings and valves examined, bore potentially honed.
In an ideal world with a pocket full of money the above suggestion is correct. However there are things that you can check and repair yourself with out a full engine disassembly.
If the problem is not fuel ( as you have suggested) the next most likely culprit is valve seating. This can be checked and repaired quite simply with the engine in situ. All you need is a socket set. Remove the complete head and take it to an engine rebuild workshop.
Not a marine shop or a Yanmar shop. Somewhere that does diesel cars or trucks.
A new head gasket, refit the reconditioned head and start her up. Again in a perfect world.
If that doesn't solve the starting problem, move to option 6 with a removal, disassembly, inspection and rebuild.
The head will have been done already.
gary
You mention;
gary
