simonfraser
can i just connect 12V to it and tap the conector to make it pump ?
is there a polarity ?
tnx
tnx
They're metering pumps and require a pulsed signal. You would pump one pulse every time you tap it, so you _could_ do it that way I guess
Our diesel heater has a key combination on the control panel that makes it pump fuel while not running for the purpose of priming. Maybe yours does too - did you peek in the manual?
When it's working it gives a definite 'clunk' every second or so.Wallas 85dt
had it appart yesterday, the pump has two identical black wires, no polarity
fitted the new spare pump, that one fired the hob up no prob, could actually hear that one click in a much more postive way
just noticed the parts come with a 2 year warranty so will be sending the dud one back
be advised to def wear some sturdy disposable plastic gloves as there are plenty of sharp edges whilst refitting the pump
