Diesel fuel getting into oil
choulihan
3 Apr 2004
We have a Brewer 44 with a Perkins engine. Diesel was getting into our oil so we had our fuel injector pump rebuilt for $400. The pump was re-installed and we are still having the same problem - getting approx 1-2 quarts of oil after motoring for 2-3 hours. Does anyone have any ideas what else could be causing this problem.
milltech
31 May 2001
Worcester
www.iTalkFM.com
If the fuel return to the diesel tank runs under the rocker cover and it has a leak, that may be your answer. I'm no engineer but it happened to me on a Ford Sabre a few years ago. Didn't take an engineer more than minutes to fix it as I recall.
<hr width=100% size=1>John
<A target="_blank" HREF=http://www.allgadgets.co.uk>http://www.allgadgets.co.uk</A>
pmorris
4 Feb 2002
West Midlands
It might be a leaking diaphragm on the lift pump which would deposit diesel straight into the sump on most engines. (Not familiar with that engine).
andyball
1 Jun 2001
think you'd be right- a perkins diesel locally did exactly that due to a faulty lift pump.
Heckler
24 Feb 2003
usually the lift pump diaphragm got a hople in it, then the fuel goes past the seal where the crank goes into the engine
stu
<hr width=100% size=1>http://www.beneteau-owners-association.org.uk
