Ross D
I need some advice, our Volvo MD7A keeps cutting out when the throttle is put back to neutral. It is fine once the engine is warm but manoeurving in marinas etc when the engine has just been started is a pain.
The idle speed hasn't changed or been adjusted so I am reluctant to simply tweek up the idle so that it stops, because that won't cure the cause only mask the symptom.
My first thought was to strip and clean the injectors, I haven't serviced them since I bought the boat a few years ago so they are probably overdue for some maintenance. If this is the case can anyone suggest where I can get MD7A injector servicing kits or new injectors if it comes to that.
Many thanks
Ross
Many thanks
Ross
