Refueler
Just to dispel a few myths...
Ok - but care to choose what you are trying to dispel ...
Adding anything to a tank that is already contaminted with bug will NOT clean it. It may (if you're lucky) kill (most of) the bug that will then settle to the bottom as sludge ready to block your filter.
True if all you add is Biocide. That is basically just a killer. What is needed is an Enzyme that breaks down the bug debris to minute size and capable of being burnt.
A bigger filter will probably just take longer to choke on this in rough weather than a smaller one, but choke it is still likely to do.
True in case of debris not broken down.
Polishing fuel cannot remove bug in the tank, it only cleans the fuel. If you return the polished fuel to the tank it's a complete waste of time as you've done nothing to remove the sludge settled on the tank's bottom but the engine will remain happy on the clean fuel - until the filter clogs again.
Fuel Polishing has no effect other than removing physical particulate and most systems I read on forums / online actually have micron size filters LESS than a decent engine fuel filter. I conducted a trial in my own lab for my own interests ... this was back in 2008 where I used various retained samples of Gasoils (Heating Oils through to ULSD).
First a small amount of each was passed through lab filtration to determine levels. Second large part of each was contaminated and allowed to develop. No biocide or additives were given. Filtration again of part of that part to determine change.
The remainder of the 'infected' samples were each passed through a system of pump / filters that had same micron size as a contributor on these forums had been advocating all those years ago ... the circulation was repeated many times.
Finally all samples were again checked for levels and also visual appearance.
Results ? Particulate was barely changed. Colour was slightly clearer in the darker grades.
Why did I do it ? I had over 1000 litres of retained Gasoil that no longer needed to be kept and I wanted to use in the boat ... plus I had already suffered blocked filters. That fuel in the end was used as fire starter and blended off slowly .....
That which was blended off and used in the boat - had Enzyme added .... even though the ratio of that to 'fresh clean fuel' was extremely low.
You can now understand my view on Fuel Polishing ...
Solution? Have bug? Merely removing and plishng the fuel is pointess. The sludge won't be removed. Totally empty and blast/scrub tank clean on all internal surfaces inc walls and top. Ensure especially the bottom is totally cleared of crud. If the tank is much baffled then so will you be as there isn't a ready solution bar bigger/parallel filters and lots of bug killer. Fuel removed can be polished and returned to the tank once it's internal surfaces are cleaned off.
Problem is most tanks cannot be cleaned as you suggest - take my 80 ltr tank ... its a truck tank that has 3 compartments to it with through flow lower sections ... designed to reduce fuel movement and fuel starvation. Only way to try clean that is circulating fuel ..
Not yet got bug?
...Better. Use additives to prevent it.
Moral? Don't risk it, habitually keep tanks full as full as practical, esp on layup with biocide mixed in.
As with most diseases, prevention is easier and less painful than cure.
ALL middle distillates and heavys have Bug ..... even Lubricating oil in fact. Reason Lub Oil does not usually end up showing it - is due to the blending and production processes that near eradicate it.
If people don't believe about Lub Oil ............... I can relate an event :
Petroship A ...... 40,000 ton Motor Tanker. On sampling the Lub oil of the main engine ... particulate was observed. Ship was then suspended from ops and we were anchored while main engine was drained ... and we then did internal inspection ... yes we could poke head in and look ! The special paint on the sump walls was seen sliding down as if there was goo between it and the steel. The goo was living organism that had grown in the Lub and then got behind the paint.
Engine was steam cleaned and then fresh oil added.
The old was blended off into the fuel ........ not my decision ...
It may be a ship - but that Lub Oil is not much different to what you have - other than it being larger volume and Industrial Grade.
Just to comment ...
