Depth sounder poll
How is you depth sounder callibrated?
  • Depth of water
    Votes: 35 28.9%
  • Depth below keel
    Votes: 59 48.8%
  • Depth below transducer
    Votes: 24 19.8%
  • Other
    Votes: 3 2.5%
  • Total voters
    121
snowleopard
Oxford
To complement Babylon's thread on echo sounder calibration, here's a poll.
Just realised how clumsy the poll options are on the new forum - only one question allowed. I was going to ask about which scale you use and how deep you set the alarm. I expect it would be too difficult to upgrade the forum software to the old level - Dan???
fireball
15 Nov 2004
Scale - Meters, because I'm young enough to understand them! ;) Oh - and all the charts are in meters.
Alarm - none set - it always goes off at the wrong time!
flaming
24 Mar 2004
So.... It depends.
Racing - clearance. Cos when I'm hurtling at the shore with 3 other boats in close attendance I want the important data (when am I going to crash) to be as simple as possible.
Cruising - water depth. To make the tidal calculations easier.
Amazingly I don't seem to have much trouble changing between the two.
colingr
21 Sep 2007
Solent
Depth under transduce = depth under keel for me and only a couple of inches from water depth.
Measured in metres,
No depth alarm unless I'm exploring upriver or for fun when I'm playing navigation by depth contour.
Rowana
Two steps lower than the ships' cat
17 Apr 2002
NE Scotland
Depth below keel for me. That way I know if it's getting close to zero, I'm just about to hit something!
jamesjermain
Cargreen, Cornwall
Scale - metres
Depth alarm - varies depending on nature of the bottom, swinging range (if at anchor), boat speed (if under way).
My sounder is set to depth below hull, in fact, as I have lifting keels. I'm thinking about changing to depth below daggerboard when fully deployed because it really isn't a good idea to run a foam cored composite board into a rock. But then its going to register a minus figure when I'm sounding into a sandy beach or muddy anchorage. Oh! It's all so complicated!
michael_w
8 Oct 2005
Usually meters, though if I'm using American charts, I'll change to feet/fathoms.
Never use the shallow alarm. Being based on the East Coast, to have a worthwhile clearance in terms of time/depth the wretched thing would be squeaking all the time.
A winter project is to change the basic echo sounder to a fishfinder; much more useful. See bottom trends, excellent for judging the bottom for anchoring and might even help me catch my lunch.
cliffordpope
28 Oct 2005
Pembrokeshire
My basic Target 2 doesn't seem to allow a negative keel offset (to show actual depth) so I just leave it at transducer depth. I don't think they are very accurate at depths of about 1 metre anyway.
alan_d
15 Mar 2002
Scotland
Always metres, depth of water with the echosounder (but it tends to give up at about 20 metres) and there is no facility for an offset on the fishfinder so it reads depth below transducer. Tend to keep the shallow alarm at 3 metres so it alerts me if I am straying somewhere I didn't mean to go.
Billjratt
9 Sep 2004
Firth of Clyde
Feet, because I can relate to them, alarm 3ft because I can't make it smaller or switch it off (ST60), and depth under the keel because that's what I'm interested in.
Anchoring is done in boatlengths, the chain being marked every 30ft. Ususally 1/2 length to the floor at mid tide, then 2 or 3 on the floor depending on weather and crowding. That way I can easily estimate my maximum full-chug swinging circle without being technical.
TamarMike
15 Aug 2008
South West
Same here with my Nasa one.
(However the lead line shows actual depth, and is more accurate at shallow depths :))
Refueler
13 Sep 2008
Far away from hooray henrys
I say below transducer but it must be slightly different as another 25cms is actual draft. If I measure the height of top of transducer to waterline - it must be more than 25cm ... BUT I know the error and add accordingly.
At 70cms I touch bottom. Actual draft is 95cms. My Echopilot duo reliably reads up to 0.5m and down to over 40m blasting through 50mm of solid GRP. I reckon that's pretty good for a budget model. Castor oil has never been topped up in 10 yrs, it's still same with no leaks from tube bonded to hull. :p
I am now going to find my 'destructions' and read up about correction of reading ... as when I've tried to correct before - it's played silly B's !!
Danny Jo
13 Jun 2004
Anglesey
Depth of water, because that accords best with ordinary conversation, and because logged depths can be communicated to others without faffing about with draughts.
Depth in meters, because I've never been able to fathom why people use feet.
AngusMcDoon
20 Oct 2004
Up some Hebridean loch
Scale - metres
I have variable draft too, so that's why I set it to depth of water.
