Dedicated engine battery - what to buy?
sailorman
21 May 2003
Here or thertemp ashore
Planning to install additional battery for engine start only, instead of using leisure batteries on 1-2-Both switch.
Assuming a car battery, any suggestions or preferences?
Its going on a Beta 35.
i have 4 x 115 Ah leisure one for the engine 3 domestics.
37.5 hp 4 cylinder Nanni.
this has served me well for the past 14 yrs
the present bank came from Battery Megastore
MoodySabre
24 Oct 2006
Bradwell and Leigh-on-Sea
I had to buy a new starting battery - previously I had a 110AH but the new one is 76AH but with higher CCA. It kicks much better. The higher the CCA the better - 550 or more. The problem is that the CCA value is often not shown.
VicS
13 Jul 2002
The owners manual suggests 65 to 75 Ah capacity with a CCA rating of 450 to 540 amps
Suggested Minimum Engine Starter Battery Size
Beta 10, Beta 14, Beta 16, Beta 20: ........ 35 - 50 Ah, 350 - 400 CCA
Beta 25, Beta 28, Beta 30, Beta 35, Beta 38, Beta 43: ..... 65 - 75 Ah, 450 - 540 CCA
Beta 50, Beta 60: ............ 100 - 120 Ah, 580 - 670 CCA
Beta 75, Beta 90: ............ 150 - 180 Ah, 1050 - 1200 CCA​
A car battery of your choice that satisfies those requirements .
tarik
27 Mar 2004
Broadstairs Kent
Battery CCA
I am in the market for a new battery, could you please tell me what is the CCA all about ??
many thanks
David
VicS
13 Jul 2002
many thanks
David
As said it is an indication of the current that the battery can supply. For a starter battery it is far more relevant than the Amp hours capacity.
BUT there are two systems which can get muddled up.
CCA is measured at a low temperature ( 0° F ) and is the system for automotive use.
MCA is the system which may be used for marine batteries. MCA ratings are measured at 32°F / 0°C
Dipper
30 May 2001
Dorset
I bought a Lucas 12v Sealed Heavy Duty 85AH Leisure Battery from Alpha Batteries earlier this year. It is listed as 700 CCA (cold marine engine cranking) and was (still is) £73 inc VAT and free next day delivery.
VicS
13 Jul 2002
Link does not work. I guess you mean this one .... click the picture.
I note that it's 700 marine cranking amps (MCA). That would be about 525 cold cranking amps (CCA).
I'll be buying a new leisure battery next year ( a bit smaller than that one) So far Tayna batteries look the most competitive for what I want.
CaptainBob
7 Nov 2007
North Yorkshire
www.yacht-forum.co.uk
I've bought a number of batteries from Alpha Batteries and all have been great.
For engine start, as others have said, it's mostly about the CCA, not the Ah. Low Ah also means it will charge back up quicker once the engine is started - but obviously having some spare Ah for the time it doesn't want to start, or as backup leisure use, is handy.
Because it was going to get heavy current draw on it every time I used it, and therefore probably need replacing relatively regularly (or so I thought), I went for something as cheap as possible with high CCA and acceptable Ah according to my engine manual (beta marine). It has been absolutely fine. Bought it ~3 years ago. Used it a LOT (live aboard, cruising in UK, mostly without permanent berth). And it's still absolutely fine. Was not a lot more than £50 delivered IIRC.
Tranona
10 Nov 2007
If you have the space, then any battery for a small diesel car will do the job. I have a Bosch starting my Volvo 2030. However, if you are short of space - for example if you want to fit as big a house bank as possible then consider a starter battery such as a Red Flash. About one third the size of a lead acid with the same cranking capacity, but can be mounted in any orientation. More expensive inevitably but potentially longer lived.
