jonsdl
New Member
Hi all,
I’ve recently purchased a Sealine S38. With lockdown restrictions I was unable to be present for the survey but the engines were described to be in ‘very good cosmetic condition’ and nothing was flagged about any rust or corrosion. To my surprise upon delivery of the boat after having a good look around I found substantial rust to the lower part on one of the engines. I have yet to inspect the other as I was pressed for time. There is also now a build up of residue around the heat exchangers on both engines which wasn’t present on my brief viewing before purchase.
The residue on the bottom of the engine bay was also not present on my viewing but was present after survey, road transport and a 5 minute trip on the water from the crane to my berth.
I am presuming that the heat exchangers are blocked. On the final image you can also see a dribble of what I presume to be water.
Am I panicking about nothing or should this have really been noted and taken more seriously at survey?
Any advice and/or opinions would be appreciated.
Thanks.
Thanks.
