st599
Any discontinuity in a coax connected to a transmitter causes some of the transmitted power to reflect back. The bigger the discontinuity, the larger the impedance mismatch, the bigger the reflection. Why bother on something that could be safety critical when you can add 2 connectors and a barrel?
Nope, the cable impedance depends on the distance between inner and outer being correct. This is why cables have minimum bend radiuses too.I wouldn't worry too much about the dia. as long as you can insulate the inner from the sheath and
