Cutless Bearing
  • Thread starter Thread starter Guest
  • Start date Start date
A few points re cutlass bearings:
The most wear will be at the after end of the cutlass bearing, most likely caused by "whip" of the prop shaft because the prop is out of balance. You mention sharp jagged edges on the prop blades. This breakdown may be caused by softening of the bronze through anti-fouling of the prop, for example. Never AF the prop, as it causes the metal to go soft and reddish.
Remove the propellor and have it balanced. This usually costs a bit of area off the prop, but it has to be done. Sometimes a new prop is the only answer to achieve quieter smooth motoring.
Larger yachts sometimes have an extra cutlass bearing just aft of the stern gland / stuffing box. These can be very frustrating to deal with, and sometimes require the removal of the engine to get at. Check for wear and hopefuly leave well enough alone!
The bearings are typically constructed of ribbed rubber making a tight fit to the shaft, with bronze or sometimes that 70s fibre (whose brand name I cannot think of right now) on the outside. There are a multitude of metric and imperial sizes available, so make sure you measure the original carefully. Contact Mike Bellamy of Lancng Marine for a replacement. He is the king!
The bearing is often held into the housing by one or two grub screws buried under the anti-foul.
Please note that sometimes it is as cheap to buy the entire bearing AND housing. This may be the better option if you have damaged the housing getting the old bearing out. Good strong tools and localised heat are usually required to remove the originals.
A tough job, but worth the effort. You will find that you can comfortably use 300 to 400 more RPM, without your brain going numb.
Courage.
Tuscair.
Re: Tufnal ????
MTB,
Don't you mean TUFNOL?
Laminates made by impregnating layers of paper, woven fabric or woven glass with a resin. Many layers are then stacked together in a press and heated under pressure, which cures the resin and bonds the layers into a solid infusible form. !! (taken straight from the catalogue) Can absorb water, but does not corrode. You used to be able to get Tufnol cleats and blocks with Tufnol sides - both good & strong.
