Cruising yacht without genoa winches?
telford_mike
9 Jun 2007
Winter : Switzerland | Summer : Ionian
Spotted a boat for sale (Jeanneau 34.2, circa 1999), which is not fitted with genoa winches - the sheets are led to the coach roof along with the other control lines.
I've never come across this on a modern AWB. Does anyone have any experience of such a setup, and would it prove awkward in everyday use?
Grumpybear
30 Mar 2005
Devon
Standard on the 34.2, though I've never seen it on other boats. It seems to work, but for short handed sailing you do need a reliable autopilot!
sailorman
21 May 2003
Here or thertemp ashore
More like non overlapping Jib set up than Genoa
Heckler
24 Feb 2003
My 95 bene 351 only had one coachroof winch, had jammers on the sheets, was tricky to work out in a hurry!
Stu
Hypocacculus
15 Jun 2014
Planet Earth
Hmm. I see that the genoa tracks are on the coach roof, and the self tailers by the companionway are doubling up as genoa winches. As I've never used a boat set up like this, any comment of mine would be mere speculation.
My cynical side says it's convenient cost cutting for the boatbuilder and I can't see any benefit to the user. Mind you, as its based in the Ionian, there's no wind most of the time anyway so it's probably perfect...
flaming
24 Mar 2004
Had it on my Dad's old Legend.
If you have the jamming turning blocks for the sheets it can work ok, as when you need to do anything with a halyard you just lock off the sheet at the block, do what you need to do then put the sheet back on the winch. The ideal solution though would probably be to fit the spinlock winchfeeder like this in in front of both banks of clutches, so that you can just lead whatever line you're working on to the free winch.
To be honest if the Jib tracks are on the coachroof I think it's probably preferable on a cruising boat than trying to get 4 winches into the area either side of the hatch.
JimC
30 Aug 2001
Lancashire
My Hunter Channel 31 has the tracks for the genoa (110% non self-tacking) on each side of the coachroof and the sheets are led via jammer turning blocks to the self-tailing winches either side of the companionway - the same winches as are used for the halyards etc. Sharing the winches in this way doesn't seem to cause any particular problems. It's handy for single-handing: I tie the jib sheets together and sheet the jib in using the winch on the windward side (the turning blocks make this easy) which is the side I'm sitting on. With the winches on the coachroof you're facing forwards as you operate them
lpdsn
3 Apr 2009
The Mystery 35 has the same arrangement. I guess the thinking is that with a smaller headsail a skilled operator can get the sheet in without really needing a winch, so the winch is just for minor adjustments when trimming.
Not sure if it'd be quite as easy with a genny, however the sheets get onto the coachroof.
sailorman
21 May 2003
A Genoa would have a wider sheeting angle than a jib & the car would be further aft & out board of the caps
