Barry777
My boat was lifted recently by crane at the boatyard where I berth my boat - which is just under 12 metres and weighs in at 18,000 lbs. In previous years they have used a slipway where they haul up the boats on a cradle using a fixed winch.
The lift out is done using 2 slings under the boat that go via chains to a conventional single jib. The backstay is released to allow the crane jib access to the slings. I don't know the height of the extended jib but the mast is around 48 feet from the deck so it is at least clear of that.
My concern is over the pressure exerted on the hull sides, particularly around the point where the hull joins the deck - there is a metal toe-rail fitted. The "squeeze" that the slings apppear to exert as they go to a single point at the jib looks quite eye watering. I have asked the yard manager why they do not use spreader bars which would allow the slings to be more "vertical" and similar to the lift using a travel hoist. However, I was told that it was not necessary. I'm not convinced by his comments and it would seem to me that it is far easier for the yard to crane lift this way rather then using the more difficult and time consuming slip.
I know that the yard has had problems in the past lifting a certain make of yacht where the hull has flexed and caused cracks around the toe rail. They will not crane this make any more - and will only use the slip.
Am I being neurotic or am I right to be concerned? Are there any reference points where I can read up on this? The lift out has taken place but I would like to be sure that I won't discover any damage when the boat is re-launched. What is the view of insurance companies to such method of lifting just using a single jib lift point?
Any advice or comments will be welcome.
