Lizman
Hello,
The beam under the mast of my Elizabethan 23 is cracked. I think it has been like it since I bought it 8 years ago. It was covered in a type of 'gauze' type material, hence my ignorance. The deck under the mast is also dished and about 12mm out of level under the mast. There is also a crack at the base of the mast, on the for'ard side, presumably because its taking all the downward force on that side. The plan to to is haul the boat out, drop the mast, and bolt some ss angle to the compression posts,one on either side of the beam. I am hoping that 50mm,4mm thick angle will do the job. Top side, I am planning to put a wedge-shaped hard wood pad under the tabernacle to restore the level under the mast. In addition I will have to saw about 15mm off the end off the mast. Initially, i was going to try to jack the deck up under the mast, but I think that would be futile and possibly counterproductive. The pictures should explain whats going on, just wondered whether the above sounds reasonable. Would anybody be kind enough to comment please?
