Burnham Bob
time to change the coolant in my beta 14. it won't drain. presumably as this is the lowest part of the system any clag collects here. removed the tap by screwing all the way out. no luck. and yes i did remember to take the filler cap off to release the vacuum. putting aplastc tube on the drain nipple and blowing had no effect.
the fitting the tap screws into seems to have shoulders suggesting it screws into the larger elbow attached to the engine. should i remove the tap housing with a spanner and try to poke the blockage out? and if i do remove it is there anything on the thread or is there an o ring to prevent leaks?
any advice please?
any advice please?
