Parmesan
My yacht (1980s) has a cool box area with a Supercool refrigeration unit which I think was installed as an optional extra when built. This is a Peltier system, so I am thinking of upgrading the refrigeration to a Frigoboat keel-cooled system which would be more energy-efficient. Unfortunately, the wall of the cool box has been cut to install the Supercool unit and when I remove it, it leaves a hole of around 24 cm by 15 cm which would not be needed for the Frigoboat unit.
Do you have any suggestions on how to repair this hole in the cool box in order to provide the best insulation and appearance? What sort of foam should I use and what should I used to repair the wall of the cool box itself (the foam wall is about 5cm thick)? I can access the hole from both sides as the cool box is adjacent to one of the galley cupboards. I can’t leave the Supercool unit in place as the cooling fins project an extra 2cm or so into the fridge and the cupboard.
