Compass bubble
mickshep
9 Jan 2003
Hartlepool
When the bubble in my old alcohol damped compass got so big that the card was exposed I figured I had nothing to lose in attempting to refill it. on the under side of the casing there was a threaded bung. I used gin but could never quite get rid of all the air. A friend then told me to put both the compass and the gin in the freezer overnight, then on removal to fill the compass. This I did. the tiny air bubble that remained disapeared when the compass warmed up. It sounds silly but 3 years on the compass is still bubble less. I'm sure some one out there will be able to say why it works or that it shouldn't, but it worked for me. Cheers, Mick.
Johnjo
8 Sep 2002
Three weeks ago when I was launched, my compass had a huge bubble in it !
The card would not revolve and I was on the verge of buying a new one,
After a couple of days the bubble had disapeared and the compass was working perfectly again,
What I thought was air getting into it , must of being a vacumn caused by cold or lack of use over
the winter, I still do not really know why !
But I have hads no further problems with it and no more bubbles !
bob26
21 Dec 2002
Sussex-by-the-sea
www.tridentlottie.com
I had a bubble in compass once and topped up with alcohol.
Got rid of bubble but turned out was't filled with alcohol after all - I think it was some sort of oil.
The two mixed ok but the alcohol dissolved the luminous paint on the card!
bigmart
14 Jan 2002
Hampshire
I used Liquid Paraffin, from the chemist, although I got a funny look from the assistant, when I told her what I wanted it for.
Martin
pvb
UK East Coast
It\'s probably happened because...
The bubble's probably happened because there's a slight leak somewhere (most likely in the expansion bellows). You can top up the liquid, but if you don't fix the leak the bubble may well reappear before too long.
chrishewett
8 Feb 2002
Lincolnshire
Topped mine up two years ago with seriously strong Polish vodka, no problems since. When I'm staring at it in the middle of the night it gives me a strangely comforting feeling.
wpsalm
26 Jul 2002
various currently caribbean
its leaking ,try to find the leak only 3 places it can leak from expansion bellows bottom of the compass, filling bung usually slot headed screw on the side of the compass or bezel ... this is the ring that holds down the glass try to tighten the scews on the bezel very gently and in a cross patern ,that is north,south, east, west if the screws will take a half turn or so you,ve solved the problem if your fussy about the bubble get a professional to fix it ...
Adrian_Morgan
26 Jun 2001
Scotland
mikshep's right. Compass in fridge (with bung out). Liquid in fridge too. Top up with syringe until overflowing. Bung in. Bubble gone as liquid expands. Sestrel liquid available in bottles from SIRS (Sestrel agents). It works. I made a kit hand bearing Sestrel compass once and the instructions included the above advice about filling. Five years on, no bubble, but then I haven't used it in the Arctic (or Antarctic) when, I suppose, a bubble might well appear. In which case, instead of fridge I'll use freezer.
ozzyb
2 Dec 2001
Home Herts UK, Boat in Morbihan S. Brittany
It happened to me a few years ago with contest compass. I was told plastimo used liquid parafin in there compasses, used the fridge/freezer method never been a problem since. Can be a bit messy though and had problems getting a syringe. Good luck
