COLREGS
Nickel
8 Nov 2003
Solent
NM = nautical mile - the required separation distance between two people arguing over a different interpretation of the Colregs. It also equates to No Message which strangely enough is also the distance between two people arguing about a different interpretation of the Colregs.
I reckon the Colregs only matter in two easily defined situations: 1. Hitting something and 2. Not hitting something.
Apart from that pretty pointless really.
As to what they are: They are the distance between two people arguing over different interpretations of the Colregs.
<hr width=100% size=1>Nickel
Being paranoid simply means - having all the facts.
zefender
9 Jul 2001
quacious
Thanks for the clarification which is helpfulish. But are the two people argueing called Colin and Reginald or doesn't it matter (very much)? There's a Colin in the Office. Should I hit him?
piscosour
13 Feb 2003
Aegina
re "There's a Colin in the Office. Should I hit him? "
Yes! but only if you approach him from his starboard side, otherwise he may get standoffish about it.
Evadne
27 Feb 2003
Hampshire, UK
That only applies if you are under control. Otherwise you can hoist two black balls and if you hit him, it's his fault. I did try this but I don't have two black balls.
jimi
19 Dec 2001
St Neots
Just hit the one one on the left anyway, you're on his starboard so you've right cross rights!
zefender
9 Jul 2001
quacious
Ok, he's got two black balls now. There's a bloke been standing around the photocopier for ages. Dunno what he's up to. Shall I whack him 5 times so he makes his intentions clear?
Rowana
Two steps lower than the ships' cat
17 Apr 2002
NE Scotland
Re: Also
Not with that bloody great motor boat of his, I hope.
Remind me to keep WELL out of his way just in case . . .
Evadne
27 Feb 2003
Hampshire, UK
I think if you produce two short farts and one long one you can pass him to port. Unless he is racing, in which case he may get abusive for leaving him in your disturbed wind.
tcm
11 Jan 2002
Caribbean at the moment
Re: Hitting col or reg
You should stand about i think, and if colin (or reginald) hits your stanchions, then there's definitely a risk of collison, and of course then they've hit you, and the rules don't say you can't punch them after that, so it's okay.
If someone hits your boat ever, best thing is to point to the middle cleats and refer to them as "rowlocks", which means you are always ok.
piscosour
13 Feb 2003
Aegina
I think that is allowed as long as you stay down wind of him. But make sure you keep a proper look out at all times.
