Cockpit carpet
ianainge
15 Jan 2003
Hampshire
My Targa 31 has a grey ribbed rubber backed carpet in the cockpit, but the rubber backing has disintegrated does anyone know where i can get a replacment?
tcm
11 Jan 2002
Caribbean at the moment
This is a job for Castorama, the best diy shop in the world, but in france.
So, allied carpets. They only last for one year. The very cheapest most horrid gear.
Or, whislt at a trade show, make sure you are in crap clothes, pretend you are part of the breakdown team, hide in the bogs, half an hour after the show closes all the carpet gets chucked unless it's carpet tiles.
byron
RIP
UK -Berks
Best never use rubber baked carpet where it is going to get wet as you will find the rubber just comes off and sticks to the fibreglass making it messy. The best carpet to use is the stuff that can be washed in situ. However! If you want loads of free carpet go to Fawley Meadow right after Henley Regatta they literally throw away rolls of it but it is rubber backed.
ô¿ô
BarryD
10 Sep 2001
Bathtub
In a prior life as a slum landlord I used to buy hessian backed stuff in room sized remenets for about £40. Easilly more than enough to do a cockpit, trouble is you'd need to edge it (I used to stuff it under the skirting board with a spoon) but that's only iron on tape - it would do a season or two...
Course it was pink which might not suit a fab Targa owner <G>.
Best if you can use the old caprets as paterns so try not to destroy them when you lift them.
IMHO & FWIW, NWGOI.
Barry D.
stewart
4 Jun 2001
London
Just had a really good one made up by a company called Wizard fabric (I think) in Plymouth, contact details below. I think they used to or maybe still do make all the standard Sunseeker ones and did a really good job, not too expensive and quick. Highly recommended.
Wizard Fabrics
Unit 1 Breakwater Rd, Plymstock, Plymouth (01752) 482222
boatmad2
22 Nov 2001
North East, Teesside
Arco the industrial supply company do a shower matting made of coloured rubber ribs with cross laid black rubber ribs underneath comes in various colours easy to cut and lay also any water drains away through it great for cockpits ive used it in my open boat as flooring non slip as well
I fitted some cheap cord at 99 p per sq yard, water runs out ok and at that price you can throw it away at the end of the season helps when you have boatmad mate in the trade.
Paul js.
