Coach trim
Could any of you kind gents/ladies..????
tell me where I can obtain some new coach style trim for around my boat, The original is aluminium with a black rubber insert and I would like to try and keep the boat original if poss...
any hel would be greatly appreciated.
John
If you are referring to the fendering strip, I had trouble with the rubbery plastic trim falling out of the aluminium channel due to shrinkage with age. Birchwood kindly supplied me with replacement trim strip at reasonable cost.
Nick
Nick
Thanks for the info, you would'nt have a number for birchwood or a website address by any chance.....
Cheers
John
I had the same problem on a Fairline I had before my Birchwood and they used the same trim so I think it is pretty common. Its a sort of D shaped rubbery insert which fits into channeled aluminium and covers the rivets - is that what you are after?
The Birchwood website is www.birchwood.co.uk and I ordered by e-mail through that. Actually they sent me loads and I may have circa 10-15 meters of the stuff left. How much do you need?
Nick
Nick
Many thanks for the reply, I have a 18ft Dateline Bounty. The trim would be required to go round the whole boat.....rough gestimate......42-43ft.....
It's the same stuff I think....D shaped with rubber insert to cover the mounting screws......
If you have any spare Let me know how much you want for it and we will arrange something.......
Kindest Regards
John
eddieperkins
Bungay, Suffolk
Hi,
Try Wilks Rubber & Plastic, there is a branch here in Ipswich and they sometimes advertise in the boating press (PBO?), havnet got a number though, also Seals Direct on 01425 610967, havnt used them though.
Regards, Eddie
