Grumpydev
The terminals on one of my alternators are a little corroded, which I suspect is what's giving me an intermittent alarm when running at low revs. My intention is to take each terminal off in turn, clean it with a wire brush and some contact cleaner, then re-attach; what do I need to disconnect to do this safely? It's the port alternator, which has its own separate starter battery, so I'm thinking I just need to disconnect that one (either physically or isolate it if there's a switch, haven't actually traced the cables to check yet)
It's a Sealine S34 with KAD32s if that helps for specifics.
