Chinese diesel heater woes
Gerry Hargreaves
24 Nov 2020
Hi I bought a diesel heater . It worked fine for 6 months then one day I went to the boat and the heater fan was running. Couldn’t shut it off . No heat just a running fan . No codes , the only way I could shut it off was pull the fuse. It replaced the controller and the lcd controller , no luck . I put power back to it the fan starts and that all I get. Need help if anyone knows about this problem . Thanks in advance. Gerry
lask
28 Mar 2019
Athens Greece
You have to look if it gets diesel, it may have a clogged filter, you have to see if the injector is clogged and then go to the electrical system (board) where you will see if it gives a spark(oil preheating )
, I do not know what you know if you can do it yourself or if you need . I wish you good luck
Elessar
10 Jul 2003
River Hamble
They are £100. Buy another.
Cheaper than most webasto/eber spare parts.
Mines needed a new glow pin which was over £20. Keep the old one as spares.
fredrussell
24 Mar 2015
Gerry, have you joined the Facebook group for owners of these heaters? A wealth of info on there. These things are so cheap though, there is some sense in what Elessar ^^^ suggests.
Hadenough
9 Jan 2011
No fixed abode
Are you saying that the heater fan started up on its own while the boat was unoccupied?
Rappey
13 Dec 2019
Ebay has lots of parts. Glow plugs around £10.
Could the motherboard be at fault? Around £13 or £24 with lcd controler and remote control.
You can keep swopping parts out or get another heater and then have lots of spare parts.
Rappey
13 Dec 2019
I'm into my 3rd winter and approaching 350 hrs. Only fault was a glowplug so bought 2 for £17.99
There is a used eber one on ebay at £50 !
Got to love how when someone has any other fault on a boat people offer help but mention a chinese heater and all some have to say is how bad they think they are.
Beneteau381
19 Nov 2019
They dont have an injector, the fuel is just pumped through a small pipe on to a metallic gauze tube. They dont have a spark either, the flame is initiated by the glow plug getting red hot. Once the fire is started the gauze keeps the flame going.
lask
28 Mar 2019
Athens Greece
You are right he has a glow plug diesel
lask
28 Mar 2019
Athens Greece
I have an eber d3lc since 2013 and it works perfectly
peteK
4 May 2009
Wirral
It's the temperature senser located on top of the heat exchanger its a well known fault with these heaters available from ebay,easy to replace utube videos show how.
Whitlock
17 Nov 2020
You must be freezing. My Webasto does over 1000 hours every year and it didn't need a new glow plug after only 350 hours. :)
