Cheap alternatives to dock fenders?
fredrussell
24 Mar 2015
These things ain’t cheap, or, to put it another way, I’m a tightwad. So, has anyone found a cheaper alternative to dock fenders?
I have a line of old fenders laid horizontally and fixed with webbing to the top edge of pontoon. Done by previous occupant of my berth but works great.
Find yourself some Large diameter rope and fix that to the top edge of the pontoon? It would hardly be noticable but be soft enough to protect your hull.
I too am looking for dock edge fendering .... the price for it is just unbelievable !
Rope was considered - but rope once it gets salt / grit in the lay soon becomes a good abrader.
I have been looking at soft white PVC U shaped and also tube .... they make fenders out of same stuff. Lot cheaper and buy by the metre.
22mm push fit pipe.. Ive got that round my dingy as a rubbing strake.. works well and is cheap.. Or the blue poly pipe?
Why do you, or indeed anybody, need dock fenders? Do you not have any fenders on the boat? If it is a bit 'lively' I arrange a step fender on the bow for some protection if I mess up my arrival at the berth .
Look at the skip or on beaches. Lots of people lose them or can't stand stained fenders.
And ignore the people who say you don't need them. Make your own choices. Not every boat or slip are the same, singlehanding can be tough, and we all have bad days. I don't need them, but I sure like them, so there.
Macrame fender can be made out of old rope. ie 10mm or so. Just get a lenght of old rope. fold it in half so you have 2 legs. Tie a reef knot near the centre loop. Then tie another reef knot and another right down the legs to use all the rope. The original centre loop makes the attachment. The knots make up the bulk that can take the crushing blow. May not suit OP need but does mean you can use smaller rope in lieu of fat rope.
Alternative I have used is off cuts of indoor /outdoor carpet. Rolled in to a tight tube of desired thickness. You can tie it into the roll with string or fit it inside a cloth bag.
ol'will
Why do you or indeed anybody, need bow fenders? It amounts to the same thing. It’s one less thing to sort out as I come into my tight berth single-handed.
We all have different solutions, one of the joys of sailing - looking at how people apply different solutions to the same problem.
If it is for your own dock, how about several layers of carpet, or better still, coir matting. You could top off with a layer of something like good quality PVC tarpaulin to stop grit etc.
Glad you added the last bit ...
My boat has a thinned Gel Coat area where rope fendering has abraded the gel ... once grit / salt gets into rope / material - its a very effective abrasive item.
Have you never had a fender ride up when alongside ? The Dock Fender is a secondary protection ..... and if your own fender rides up and sits on the dock as I have seen / had many times when floating pontoon moves etc. - then the fixed Dock Fender is well worth it ...
