Graham_Wright
Why are these so expensive?
100A Schottky Rectifiers on ebay from a fiver.
Apart from the heatsink needs already mentioned, one aspect worth considering is max voltage tolerance. Most marine diode splitters are rated at around 48v max. The £5 ones you've seen are, I believe, rated at 15v max, and anyone with a "smart" regulator could well have the alternator running at over 15v sometimes.
I wouldn't use diodes anyway. VSRs are the modern way IMNSHO and have several advantages - voltage drop being one of them.
Vetus and X-split use MOSFET's due to the very low/zero volt drop.
Has any one considered using MOSFET's in a DIY diode splitter.
Vetus and X-split use MOSFET's due to the very low/zero volt drop...
Now I am out of my depth (as usual) but surely the maximum voltage difference is that between the alternator and the battery? Worst case 6 volts?
Between alternator output and ground.
Plus this is not a smooth dc voltage, but a series of pulses ( around 27 per alternator rev) above the battery voltage. These are produced by your rectifier diodes in the alternator, so you have a nominal say 14.0 volt, but pulses that go up to 16 volt. It's these pulses that charge the battery, or the voltage in the pulse does.
Brian
This can produce the right voltage at the service battery but can produce too high a voltage on the starter battery. Consider a heavily depleted large service bank - and an almost full smaller starter battery. The voltage drop across the diode feeding the service bank increases with the current so may well reach 1.4 volts or more. The alternator senses the voltage at the bank and raises the output by 1.4 volts to say 15.8 volts. The voltage drop across the diode feeding the starter bank is only 0.7 volts because the smaller service bank is taking a much smaller current. So the starter bank is sitting at 15.1 volts for maybe several hours! This is almost an equalizing charge - so not very good for any sealed, Gel, and AGM batteries. Modern split diodes use newer technology with virtually zero voltage drops, but they are much more expensive.As has been mentioned many times, the voltage drop need not be an issue. If you are able to take your "sense" wire to the battery, the voltage drop is removed from the loop.
………but still not a pd of >15v.
As a drift, to overcome the dangers of diodes blowing due to the removal of a load, would not a simple filament lamp across the alternator output suffice?
I think 16 volt is, this is conservative value, when I was building mains chargers I would fit 45 volt diodes and thyristors rated at 2 -3 times average charger output amps. This gave a reasonable service life, 20 + years. You cannot run electronics on a 100% duty cycle, they don't work that way.
MOSFET's are very much in this criteria, how you drive them is critical, they are prone to thermal runaway, so how you install and cool them is critical. They are not nuts and bolts that you just screw together.
Why not fit a VSR and leave the alternator permanently connected to the engine battery ? When I designed our first VSR 35 years ago it was for a reason, to maintain alternator connection to battery, and avoid diode volt drop were just two.
Brian
