Changing the sheets
Where you use 'a double line of smaller stuff cow hitched to the clew', I put that length into the loop of the butterfly then soft shackle to the clew.
Someone mentioned about attaching a whisker pole. For that, I've made a coyt of stiff rope which is held to the clew with a cow hitch in the soft shackle. Happily, cow hitches don't seem to jam up in dyneema.
Now that I'm using dynema as the 'small stuff' I may as well just make it into an extra long soft shackle. Maybe cow hitched to the alpine butterfly so that it can't be dropped off the boat when changing headsail.
I think you are not understanding what he means.
The sheet is one length of rope, from the clew, behind the mast, and back to the clew. Both bowlines are attaching the ends to the clew.
Yes, this could be done with two bowlines, or one of many other connections.
Yes, I had misread it. I've since deleted the post. It's time I went to sleep?
The fenders and mooring line are usually left unattended, while the sheets, when in use, are always under observation, so it's not a fair comparison.
Cannot agree with you .... I want my sheets to be absolutely secure and be trusted to maintain set of sail. I do not sit in cockpit watching sheets all time ... and last thing I want is sheets giving out due to an unsuitable hitch !!
... After read post after post from experienced sailors telling you this is proven to be secure over many decades.
It is a suitable method. Not the only method. Perhaps not the best method for every material or sail construction. Not the method I use every time, but a method I have used several times, for many years. A suitable method. You are free to feel differently.
Absolutely I am free to my own opinion.
I regard myself - having been a Senior Deck Officer for many years - and professional Seaman ... a Cow Hitch is not in my usual 'use category'.
The only observation of Cow Hitch use is with chain stopper on ships wire mooring lines. Because it does not lock up and is easily removed once wire is made fast. It would be hard to find it used anywhere else except where coiled ropes etc are hung ...
Did you have genoa sheets on an oil tanker?
Silly billy ..... the fact is the Cow Hitch is a lazy mans hitch to just hold something temp while doing another thing. Its not supposed to be a load bearing hitch.
Have you ever worked a chain stopper ??
I beg to differ. Kite surfing kites use thin dyneema line. The lines are held to the kite using a cow hitch. These are extremely load bearing. This is universal on every kite manufacturers kites and line set up. 100s of thousands of kites using a load bearing cow hitch. Four on each kite
I knew there was a reason I didn't go Kite Surfing .....
You are making a fundamental error ..... the Cow hitch when tensioned on BOTH lines exiting is stable. It works. It becomes UNstable when only one exiting line carries load and other is free .....
You are making a fundamental error ..... the cow hitch when tensioned on BOTH lines exiting is stable. It works. It becomes UNstable when only one exiting line carries load and other is free .....
I think you are making the fundemental error. You said a cow hitch wasnt a load bearing knot. It only needs load on one side to tension the knot. Many people have talked about how hard they are to undo on genoa sheets. Does this sound like a knot that is unstable?
