dial-a-monkey
We just replaced half of our anchor chain with the same specification of chain as we have so far been using without any problems. (Quick vertical Antares v1000w multifit gypsy marked "10mm" & "3/8" = DIN 677, G43 3/8, no naval pipe)
Unfortunately the new half jams going into the gypsy only when being feed out. So DOWN jams UP is no problem.
The new chain measures almost the same with the exception of the welds which are 0.75 -1.2 mm larger.
Both old and new sections go onto the gypsy twisted (but mostly sort themselves out) often the new chain seems? more twisted and results in the dreaded "hockle" jam.
The gypsy is a multifit so takes a wide range of chains I.e DIN 677 and imperial G4 for instance, so from 10/14/28mm to 9.98/16/31mm. The old chain is 10/15/30 so is 'in range' and as I said never jammed.
I tried to stack the new chain further away from the windlass throat, to give it more time to sort itself out, this seems to improve things a little bit.
I don't see how the chain could stay twisted but if anyone has ideas? I thought about dropping it in deep water to see if it is twisted?
Also I wonder if it might just come right after using it for a bit?
The min fall suggested for my windlass is 40cm which we just make, the chain is stacked in the anchor locker to keep this fall.
Wondering if the gypsy is worn to fit the old chain and now even a slightly change results in "hockles"
Any thoughts? or experience anyone can share? all input or even musings would be appreciated!
