burgundyben
Following the broken prop incident I have fitted a pair of props that I got with the boat, she was under prop'd with 16 by 17's that should have been fitted to a huntsman with 130's, mine is fitted with 145's (should be 16.75 by 17.75), cept the props I have fitted are for 165 (16.75 by 18.5), to make my engines 165 you have to up the fuel pumps by 15% I beleive.
Question - if under prop'd will the engines over rev or will the guvnor hold them back?
Question - how do you measure the out put of a fuel pump, is it something to do with "shots" and cc's of fuel per 1000 shots?
Question - a CAV rotary pump fitted to a Perkins T6.354 should be set at what? is it a matter of winding back the throttle stop (I think not)?
Question - cant find this info on the web, can anyone point me to it?
TA
Fitting the shaft tonight, shud be launching 2mora
<hr width=100% size=1>Sod the Healey - I think I'll buy an E-Type.
TA
