cherod
Hi , can anyone advise on UK / EU supplier ? Ty R
Where did you get that , plsWhat size cat? I got one for a woods strider last year.
TyIt depends on what sort of tramp, we used a Ferrari tramp, which was common place. Older cats used a net. You can easily fit a Ferrari yourself, buying the mesh from Bainbridge. The time consuming part is lashing the tramp to the support structure.
Trampoline Mesh | Bainbridge International
Jonathan
They are in AustraliaIt depends on what sort of tramp, we used a Ferrari tramp, which was common place. Older cats used a net. You can easily fit a Ferrari yourself, buying the mesh from Bainbridge. The time consuming part is lashing the tramp to the support structure.
Jonathan
Cool , thank you for the second link , your initial one brings up the Ozz address , tyI think if you stretch your fingers and read their name, Bainbridge International, you will find, without much effort, they also have an outlet in the UK.
Whether they sell what you want - maybe you can check.
None of this is rocket science.
Jonathan
Bainbridge are big international suppliers. A large proportion of the chain imported into UK comes via their servicesCool , but my initial search only brought up the Ozz one , ty
TYBa
45mm x 5mm Heavy Duty Knotless NettingWhere did you get that , pls
Hobie are well known makers of catamarans, as are Lagoon.Hi , can anyone advise on UK / EU supplier ? Ty R
Ty , i quite like the Ferrari one , i think that is what orig one is ( french boat ) , much more comfortable to walk / lounge around on than the wider netting type , will give them a bell , tyI've just had a load of trampolines made for our F36 trimaran by Rory at SO31 Sails (part of Quantum) in Hamble, using Ferrari mesh too. At least, the middle tramps were Ferrari and the front and rear triangles more open netting so they hold less water. It seems all the French multis use Ferrari. No idea whether SO31 sourced it through Bainbridge or someone else.
Really pleased with how they've turned out.
Ty , any brand / maker names ?We have just had a winter cover made for our swimming pool , might be suitable stuff and probably a lot cheaper .
As per thread title ,What are you looking for?
Jonathan
Ty , thats what i got and ideally would be looking to replace with . If ordered a size does it come with the trim round the side do you know ?Another vote for FerrariView attachment 183430
