FairweatherDave
Been studying the old threads and still can't decide whether it is worth hiring a needle gun for my cast iron keels. I have an angle grinder so could use something on that instead. I have the fertan and primocon ready to go. But the needle gun? Some are electric and some used compressed air. The HSS electric one says it can only be used for 15 mins before needing 15 mins cool down, brochure says it is only good for light use? Do keels that take a full day to go over constitute light use?
I am tempted just to use an angle grinder on the bad bits and then just cover those patches with fertan then 5 coats of primocon and see how well the patches do over the season.
If I was just to do patches with the angle grinder it seems that a flap wheel is good for the flat areas and a wire brush fitting is good for the craters and then the fertan converts what is left and any flash rusting. Final question is can I use ordinary West epoxy in the craters before primocon, the West handbook only refers to lead keels?
Obviously shot blasting is the ideal method but that is for the future, unless I am persuaded I am simply wasting my time and should do a light rub down and anti-foul to last this summer season, and save the expensive primocon and fertan until then. Some guidance would be appreciated and I know it is an annual subject but some of you will now be wiser after your own experiences a year or more ago
