Carbon monoxide going off - possible causes?
westernman
23 Sep 2008
Costa Brava
www.devalk.nl
I have a procharge ultra battery charger, which has different settings for AGM and sealed lead acid (which all my engine room batteries are) - won't it cause issues if I just change the bow thruster battery to AGM?
I would get an ordinary car starter battery. They are designed for delivery lots of amps.
AGM will be more expensive, and I doubt you will see any advantage.
Leisure batteries are a compromise, and have less good CCA specs. They will have high Ah capacities.
There is a lot to be said for having the same kind of batteries everywhere so you don't need separate chargers.
Plum
6 Jun 2001
UK East Coast
That was it! Still pretty warm to the touch, even after several hours without charging - I thought the heads was a bit smelly yesterday, but must have been this.
View attachment 174053View attachment 174054
Any recommendations on a replacement? I guess it needs to be pretty heavy duty given how much umph the bow thruster uses.
I had the same problem of the CO alarm sounding and caused by an old fashioned "2-stage" charger causing gassing but the battery was not faulty or damaged. Fitted a new "smart" charger, problem solved and the battery carried on for another 5 years.
Grumpydev
9 Nov 2023
I have a smart charger, I might have salvaged it by topping up the water maybe, but honestly don't want to risk it.
Momac
7 Feb 2008
UK
Sounds like the existing battery is scrap if it has become very hot.
On reflection Just thinking is probably best to stick with a lead acid battery if there is only the one charger .
penberth3
9 Jun 2017
Be very careful! And be aware that Hydrogen Sulphide ( H2S ) from a 'cooking' battery will set a CO alarm off.
H2S is an insipid poisonous gas, slight exposure can dull the olfactory nerves so that you don't smell the bad eggs smell after a while. It is also cumulative in your body and toxic.
Is it really H2S from a hot Battery? I always thought it was sulphuric acid vapour. I'm familiar with both smells.
PaulRainbow
16 May 2016
Suffolk
What do you suppose AGM batteries do ?
Not true.
Not true, again.
AGM will be happy enough at 14.4 absorption/bulk and 13.4 float, as will SLA.
Plenty of production boats built with SLA domestic batteries and AGM bow thruster batteries.
PaulRainbow
16 May 2016
Suffolk
Thanks, I'll probably go for this:
Advanced LP85 AGM Leisure Battery 85ah 12v | Advanced Battery Supplies
Just need to double check it will fit when I'm next at the boat (as I stupidly didn't measure the box, only the old battery 🙈).
No big deal if we can't run the charger or invertor next weekend, I don't fancy paying postage to post one of these things back 😂
In addition to measuring the battery, make sure the posts are the same layout.
Double check the charging profile your charger is set to. Sealed Lead Acid @ 14.4 and 13.6 will be fine.
As long as the battery cables at the bow are insulated to protect them from shorting you can safely use the charger or inverter.
Grumpydev
9 Nov 2023
It's currently set to "SLA preset 2", which according to the manual is 14.6 charge, 13.4 float - "SLA preset 1" is 14.4 charge, 13.6 float - do you think its worth changing it to preset 1?
I've wrapped up the cables at the bow, and also switched the isolator off that seems to connect them to the rest of the system (although I've not verified that with a multimeter)
PaulRainbow
16 May 2016
Suffolk
SLA preset 2 will be fine.
vyv_cox
16 May 2001
France, sailing Aegean Sea.
coxeng.co.uk
As someone mentioned earlier, it is hydrogen that confuses CO meters and causes them to alarm. I wrote an article on this for one of the mags (YM I think) a couple of years ago. There may well be a smell of H2S, to which the human nose is sensitive to a couple of parts per million but it is H2 that triggers the alarm.
