jeremyshaw
Forgive the longish post, and be warned this is of little interest to anyone who isn’t savvy about electrics, but I hope someone can help me with this.
Some months ago the capacitor on my Bauer Junior II compressor melted. Bauer’s UK agent supplied me with a new one at the handsome price of £110. I fitted it and the compressor ran for a few seconds then packed up. Now it won’t even try to start. I have tried to check the capacitor as my multimeter has this function and I think it is OK but am not certain.
I emailed Bauer UK to ask them if they had perhaps supplied the wrong capacitor as the spec was different.
To which I eventually got a reply from Bauer Germany as follows
Today I have opened the W- Motor to look into and control the dates of capacitors.
The Capacitor- start motor N 27170 has got MF130 230 VAC Type Facon.
The operating capacitor has got 50 MF.
It is always with problems when a generator is not strong enough to give the power for running the unit. If the unit is also used with a long cable than the Motor get quickly overheated.
When the compressor runes than is it important to measure the power supply Ampere.
If you measure more than 14 A at final pressure than you can be nearly sure that the motor get very hot, sometimes to hot.
In this I recommend to change the motor pulley in a smaller dimension.(80 or 90mm instead of
100mm) You will loose a little bit delivery capacity but the electric power trop to approximately =12 A.
This leaves me pretty baffled. My genset can produce 30amps so I don’t feel there is a problem with it not being “strong enough”. Also I have filled dozens of bottles over the last few years so I don’t believe there is a problem with the installation, although the failure did occur after filling about 8 tanks in a row, which is probably the first time I’d done that.
So my questions are:
1. Am I right in thinking that he is saying that if the compressor draws more than 14 amps as the tanks are nearly full I should change the pulley to alter the ratios regardless of my supply capability i.e. there is a design fault? (it usually draws about 10amps on startup but I can’t say I have checked it when I’m actually filling, though I can do that).
2. The original capacitor was labelled 40 MF 450V 50Hz, the replacement BHC 100MF 260V 50/60Hz. Would that be a problem or is it OK to have an oversized capacitor as that appears to me? Is there a relationship between microfarads and voltage so that 40MF at 450V is roughly the same as 80MF at 220V? I can buy an off the shelf capacitor for less than £20 so I’d much rather do that than try again with a ludicrously overpriced Bauer one, but am not quite sure how close I have to be to the spec, especially as it looks like I might have to get two as there seem to be two capacitors in this unit, which was news to me.
3. I’ve also been told the problem might be with the cutoff switch, and asked Bauer about that but they have not commented on that or how I can check the switch operation – so any thoughts on that much appreciated.
The problem is the boat is in Venezuela and I have no chance of getting a good engineer there. I’ll be going out in April and moving it to Curacao where I can probably get help, but I fancied doing a fair bit of diving along the way, and so it would be great if I can fix this thing up myself.
Many thanks
Many thanks
