Dockhead
I'm all ears if you want to explain concretely what specific function your talking about.Im not talking about AIS, and I’m giving up there as you seem uninterested in understanding or moving forwards with the technology
Yes they do, extremely well. You can track within zones and at differing ranges (i.e. further out in front). There is a limit to number of objects tracked but it would be hard to reach it if sailing sensibly.Can somebody put this in terms that I can understand?
Do the new systems recognise and track targets, thereby calculating a CPA/TCPA solely using the radar data?
If they simply pull that data from the AIS, then that's not exactly a huge upgrade on what I already have.
This morning, I've just had a sports fishing boat zoom past me in <1/4 mile visibility. He was easily doing 20kts. He wasn't on AIS.
You're talking about MARPA (Mini Automatic Radar Plotting AID) or ARPA (Automatic Radar Plotting Aid), which I've mentioned in almost every post.Yes they do, extremely well. You can track within zones and at differing ranges (i.e. further out in front). There is a limit to number of objects tracked but it would be hard to reach it if sailing sensibly.
This is entirely unrelated to AIS which is a separate system. AIS will often overlay on the radar info but most systems will treat them as distinct plots.
Modern radar would have shown the vessel as a plot, just like AIS but with less accuracy and information. It would have given you speed, course and CPA for the vessel while also showing your and their boat on the chart, optionally with a track and an estimate of where each will be in a given timespan. Mine is usually set to 10 minutes in the future unless we’re offshore or somewhere big and empty, then its 30 minutes.
Correct. You can see an example in my screenshots in post 81. The green vector is what the radar is calculating based on its data, the red vectors are from the AIS data. Notice how it's not precisely overlaid on the AIS position, and that it takes time to update because just as in traditional hand plots, it's calculated based on changes in the target's position over time.Do the new systems recognise and track targets, thereby calculating a CPA/TCPA solely using the radar data?
per virtual radar. The Halo has two virtual radars so the total would be 20 but i agree thats more than sufficient when set up with zones.1. Checking the manual for the B&G setup I'm used it, it indicates a max of 10 targets.
I have Garmin radar and a Garmin MFD,As I’ve said in nearly every post, you clearly don’t have experience of this so please for the love of god stop pushing misinformation about this tech.
The rest of us are happily using it and have been trying to help OP with genuine understanding of the differences. You have been confusing the issue in your many posts insisting that legacy techniques are still required when they simply arent. Anyone who has done the RYA radar course and then used a modern set knows this, the course is utterly pointless. Even the instructors on this forum have said so on many occasions.
Yes, ARPA identifies the target, no its not the reason this is better. The plotter actually plots the absolute position of the object on the chart. Thats not ARPA, thats plotting and was a huge step change.
I am afraid I feel the same way ..... Binned two B&G Vulcans each little more than a year old - and just out of warranty.I would not fit B&G if it was a gift.
Sorry, but this is completely wrong. What you are describing is a basic ARPA (called MARPA when it doesn't pick up the target automatically) function, the same function which has existed since the 1990's. Nothing more, and nothing less. Already in the early 1990's, Kelvin-Hughs introduced radar overlay including plotting ARPA targets onto their ECDIS systems, and on yachts, Raytheon Pathfinders used with RL80 MFD's had radar overlays and could do this, too. I know because I owned one.As I’ve said in nearly every post, you clearly don’t have experience of this so please for the love of god stop pushing misinformation about this tech.
Mine can be set to automatically acquire targets.Sorry, but this is completely wrong. What you are describing is a basic ARPA (called MARPA when it doesn't pick up the target automatically) function, the same function which has existed since the 1990's. Nothing more, and nothing less. Already in the early 1990's, Kelvin-Hughs introduced radar overlay including plotting ARPA targets onto their ECDIS systems, and on yachts, Raytheon Pathfinders used with RL80 MFD's had radar overlays and could do this, too. I know because I owned one.
Then it's ARPA :thumb:Mine can be set to automatically acquire targets.
Mine is all Garmin, i wouldn't have B&G as a gift.Then it's ARPA :thumb:
I acquired my first ARPA-capable system when I installed B&G Zeus 3S's and a Halo24 radar last year. Before that I had only had MARPA sets, where you had to manually select the targets.
My previous system was based on the first gen Zeus MFD's and 4G radar. I liked the 4G radar very much, but the MARPA function was terrible, almost comically bad. Much worse than that of the Raytheon Pathfinder which preceded it.
I didn't think I would care that much about ARPA vs. MARPA, but I'm finding it's just night and day now compared to the system on the old Zeus. You need really good compass data for it to work really well (I'm using a satellite compass), but I'm very pleased with it.
Is yours a B&G?
Probably not, most of the work is done by the MFD.If I pair a new Axiom with an older digital radome, will I be missing out on anything important?
I think I can squeeze in a 9" (no sniggering at the back).Probably not, most of the work is done by the MFD.
BTW, i saw you mention 7" Axiom in another thread. A 7" screen is tiny, i wouldn't go smaller than 9".
Right, I should have remembered about your Garmin.Mine is all Garmin, i wouldn't have B&G as a gift.
According to Garmin ;
Acquiring MARPA Targets Automatically
You can acquire MARPA targets automatically based on MotionScope, guard zones, or boundaries.
https://www.garmin.com/en-GB/p/596974/pn/K10-00012-19/#o verview
