Lon nan Gruagach
I would be inclined to suggest OP buys the boat if he likes the deal and either ignores the crack or pop rivets a piece of alloy around the base and over the crack. As said it probably was caused by corrosion of a alloy plug in the bottom of the mast. This probably can not be removed and would require you cut off the mast to the depth of the plug. The corrosion in itself will not cause a big problem being surface corrosion in the faying surface between the mast and plug.
This part of the mast is only subjected to crushing forces (trying to shorten the mast) from pull of the stays. Rather than fail completely it will slowly crumple causing loss of rig tension and obvious folding out of the metal.
I foolishly mounted turning blocks with cut outs near the base of my mast all in one level near the bottom. With age and corrosion the remaining metal did crumple by a centimetre or so. The fix was to weld on additional sleeve outside. Certainly not catastrophic failure. olewill
Not so, not by a long chalk.
Centre of action of a sail is about 1/3 the way up from the boom, so 2/3rds of the drive from the mainsail is at the boom. 1/3rd of that is on the sheet, 2/3rds on the mast. Over all, somewhere in the region of 1/4 of your drive is transmitted to the hull at the mast step.
