lustyd
Yes I assumed they would. RYA should be pushing for that to be illegal contract terms. In France everywhere I went seemed to carry all the suppliers in all sizes. The Brits don't do ourselves any favoursFlogas do the same.
Unfortunately the RYA have quite literally missed the boat:-(Yes I assumed they would. RYA should be pushing for that to be illegal contract terms. In France everywhere I went seemed to carry all the suppliers in all sizes. The Brits don't do ourselves any favours
Picked up a FloGas 4.5kg butane cylinder yesterday. Its yellow in colour, 240mm diameter and 371mm high. The base is the same diameter as the body. It looks like the later version of the Calor gas cylinder, and takes a 21mm snap on connection.This thread is getting very long but has anyone actually got a 4.5 flogas and can measure overall height, width and base diameter for us. Please don’t repost the flogas specs from their site I don’t think it gives base diameter
That's the propane bottle as they have different suppliers, at least they mention the difference.340 to 371 mm is a hell of a tolerance...
does anyone have the exact measurements of a flowgas butain (yellow I think)
I want to fill my 4.5kg butane cylinder (POL screw on connector) from a 15kg Calor Butane cylinder (21mm clip on connection). What straight through pigtail do I need as I can’t find a direct connector (I have already bought a straight through POL pigtail but realised it won’t go on the 15kg/7kg)
Any pointers
SSG
I bought two pig tails then when to hydraulic trade counter and bought a threaded straight connector, I think they said it was M20 threaded but they will know. They just used the relevant bottle adapter for 15kg bottle and straight onto the 4.5kgI want to fill my 4.5kg butane cylinder (POL screw on connector) from a 15kg Calor Butane cylinder (21mm clip on connection). What straight through pigtail do I need as I can’t find a direct connector (I have already bought a straight through POL pigtail but realised it won’t go on the 15kg/7kg)
Any pointers
SSG
POL connectors are used on propane cylindersI want to fill my 4.5kg butane cylinder (POL screw on connector) from a 15kg Calor Butane cylinder (21mm clip on connection). What straight through pigtail do I need as I can’t find a direct connector (I have already bought a straight through POL pigtail but realised it won’t go on the 15kg/7kg)
Any pointers
SSG
You will need a 21.8 mm LH to M20 cylinder adapter for your 4.5kg butane cylinderPOL connectors are used on propane cylinders
The valve on your 4.5kg butane cylinder has a 21.8mm LH thread
Vic you’re a saviour I was getting totally lost, many thanks, Rory (SSG)You will need a 21.8 mm LH to M20 cylinder adapter for your 4.5kg butane cylinder
A 21mm clip on to M20 cylinder adapter for your 15kg cylinder
and a hose with W20 nuts on both ends
These are
Part numbers 4012, 4014 and 4017 respectively from Will Hayward All Products | Whayward
View attachment 150329 View attachment 150330 View attachment 150331
These are
They say that now, but may very well change their mind if enough people swap over, which was the point of my gas rage thread. The reason we're in this mess is lack of demand for an alternative to Calor. Once they get 20 people a week asking they'll have a good business case to stock them.we will not be stocking the the small FloGas bottle but might order one in
