Calibration question KAD300
About Time
10 Sep 2014
Denmark
Hi,
Question is ... do I do a calibration of the throttles after replacing a starter battery ?
I plan to cut power by main switch and then replace my starter battery on my twin volvo KAD300 installation. Since the EDC module is out of power when main switch is cut I guess a calibration should not be needed ?
petem
Cotswolds / Altea
www.fairlineownersclub.com
Hi,
As you say, it's normal to use the battery isolators to cut power to the engines / ECU so changing a battery won't require any re-calibration.
