Bulbs as Heaters
Ian_Rob
31 Jan 2008
There is a thread on an American forum that questions the safety of using light bulbs as a heat source in a bilge (and presumably therefore an engine bay) though much of the argument relates to sparks and contributors guesses on what their insurers interpretation would be.
Assuming the gas is off, I can perhaps see a risk where there is petrol about but diesel.....???
Ian_Edwards
9 Feb 2002
Aberdeen Scotland
I've successful used a 100 watt old style tungsten filament bulb as a heater in the cabin of a small yacht. I suspended it on its flex about 1m below a hatch, which was left open on the ventilation catch. I.e. a couple of centimetres.
The air circulation caused by the hot bulb was suffice to keep the boat well ventilated.
I left the bulb on all winter with any problems.
Momac
7 Feb 2008
UK
I think some people see risks in everything.
Rather than a bulb I use a tube heater in the engine bay and a radiant heater near the calorifier. Both controlled by thermostats .
I dont have any oil of fuel leaks but the engine bay heater is located clear of any possible drips from the engine.
sarabande
6 May 2005
here are some figures for the surface temp of incandescent bulbs
25W - 110F
40W - 252F
60W - 260F
Those are for ambient air temp of 77F.
In a closed space (e.g. engine compartment) in theory all the bulb W is converted to heat/light energy, either radiant IR/visible spectrum, or through convection. But shining a light or relying on minor warm air movements (and the tendency of warm air to rise upwards) seems a very ineffective way of indirectly keeping the engine block warm.
To me, the sensible (joke :) ) way to keep the engine warmish is to wrap a heating strip round the block or some handy pipework and then heat the block directly. OK, in the end, the warm air from the engine will rise up to the top of the box...
http://www.coleparmer.co.uk/Category/Heating_Tapes_Cords_Blankets/2059
https://heatingtapes.com/collections/silicone-industrial-tape
I wonder whether putting light bulb into an engine box is more about the perceived comfort factor of the human being.
PaulRainbow
16 May 2016
Suffolk
But why ?
My car engine lives outside and gets sprayed with dirty water everytime it rains and dirty/salty water all winter. Why does my boat engine need to be nannied ?
ghostlymoron
9 Apr 2005
Shropshire
I've asked similar questions before and was told it's irregular use and salty environment. But still seems odd to me. My current car has done 95k with minimal attention and previous ones did 150k before I swapped them. The engines were still starting and running well and not consuming oil or excessive fuel. By minimal attention i mean serviced at recommended intervals which is just oil and filter changes for a diesel.
Boat engines don't survive as well.
But why ?
doug748
1 Oct 2002
UK. South West.
I have used a bulb in an inspection light housing for the last 4 winters or so, placing it underneath the sump. Its on a timer so the power use is small but it keeps condensation off the engine in cold snaps and nothing is lost as the waste heat helps to keep air moving through the boat.
When I asked, on here, I was assured that a tube heater would be no more efficient, the bulb is smaller and handier and I use the inspection light anyway.
Many will recall the days of car sump heaters - paraffin devices placed under the engine of our Dad's old petrol cars.
ghostlymoron
9 Apr 2005
Shropshire
When I was on construction sites in the 70s, we used to light a small fire under our Winget dumper to warm the engine before attempting to hand start it.
lw395
16 May 2007
I do know someone who nearly set fire to his boat with a bulb. Somehow the lamp got moved and ended up on the chart table which got properly scorched. I suspect it was a halogen lamp.
David2452
6 Jun 2001
London & Fambridge
My major objection is that a bullb will probably blow far more frequently than a tube heater will fail and therefore less reliable as a protective device.
martinriches
8 Jun 2005
London
A lot of cars are kept in a salty environment as well. The marina car park where I keep my boat is usually full. The village nearby is full of cars and vans. The engine on my boat is enclosed in compartment, yes it does have some ventilation but no where near that of a car engine in a similar environment.
Martin
Ian_Rob
31 Jan 2008
Re: Bulbs as Heater
I bought a 150w ceramic bulb; the type used to keep reptiles warm but having checked it with an infra red thermometer the bulb has a surface temp of at least 400 degrees C, far hotter than the Sarabande's figures for an ordinary bulb. It may well be hotter still but that is as high as my IRT will measure. Thought it was a good solution but not so sure now.
No Regrets
9 Jul 2007
Re: Bulbs as Heater
The thought of replacing a cheap reliable tube heater with a bulb fascinates me, and not in a good way!
The tube heater should last for years, if not decades, exists only to provide heat, and is tough, resistant to knocks, therefore the correct tool for the job.
A bulb is a bit futile by comparison.
Why on earth would anybody want to replace the inferior item with the obvious choice!?
Comparing a car engine, which is totally protected with it's sole coolant source with a boat engine which usually has both the internal (coolant) cooling and the external (raw water) coolant is really thick.
PaulRainbow
16 May 2016
Suffolk
Re: Bulbs as Heater
Probably not as thick as thinking a tube heater in the engine compartment will somehow protect my engine from whatever the left over seawater is doing to my already 35 year old engine. Doh!
Ian_Rob
31 Jan 2008
Re: Bulbs as Heater
From an earlier thread, 60w is a little on the light side for the volume of my engine bay where conditions drop below -2degrees C. A 120w tube heater, which should be installed horizontally, is too long to fit. 2 x 60w tube heaters (£40.00), 120w Ceramic Bulb (£6.99).
maby
12 Jun 2009
Does your car have a seawater side?
It's not only the engine cooling circuit. Living in the south of England, I'm fairly relaxed about the engine - the freshwater cooling circuit is protected with antifreeze and its exceedingly unlikely that the raw water side will ever freeze. My concern is more the drinking water supply to the boat - that could freeze and burst pipes.
