Norman_E
Encapsulation 2
My method works well, though the foil is quite hard to peel off, which may be down to my use of an old spraycan of dry silicone as a release agent.
I have however found a little problem, which might happen however you do the job. The transducer was pushed firmly down, with four little pieces of just under 1mm thick plastic glued to it with superglue, to act as spacers. On peeling off the foil, only two were visible, as the transducer appears to have tilted slightly. Careful probing of the potting compound, aided by a small air bubble, reveals that the tilt is very small, with the base of the transducer about 1.2mm from the bottom at the high side.
I am carefully rubbing the base of the unit on a piece of fine sandpaper to reduce the average thickness of the potting compound below the transducer to 1mm. I doubt that it is critical, but rubbing the unit down with the sandpaper on a flat surface is producing a flat base with no ripples in it where the foil did not sit perfectly flat. I will fill the little hole when I pot the other transducer.
