AntarcticPilot
Dear All,
I have just started to build a D5 dinghy. So far so good! I expect it will take a while to build; I will need to take it easy as I learn new skills. So far, I've marked out the frames on the wood, using the old principle of measure twice, cut once!
There are a couple of design issues that I'd like to ask for suggestions about:
- I intend to tow this dinghy; it's too big to carry on deck under way. What is the best way of arranging the fastenings for a towing bridle? The major constraint is that the dinghy might flood while towing, putting a large strain on the towing attachments
- I'm unhappy about putting eye-bolts through the bow transom - that seems too weak, putting unnecessary strain on the joint between bow transom and skin.
- I've considered putting stainless steel strip with an eye in it between the rubbing strake and the hull. Concern there is a permanent, rather sharp-edged protrusion on either side at the bow.
- Alternatively, how about making a couple of holes between rubbing strake and hull and using them to fasten a rope bridle?
- The dinghy will be landing on Scottish beaches, replete with rocks and mussels! Besides covering the bottom with glass-fibre/epoxy, is it a good idea to put additional rubbing strakes on the bottom? A metal strip along the keel sounds like a good idea.
