rafiki_
Re: The plant pot
Great progress Wayne. Keep the updates going please��
W
making progress and that must be giving good feedback.
Are you going to have a searchlight and horn/PA on the roof ? That will break up the outline and also provide additional night/fog/bridge approach faciiities ?
And looking ahead, what nav/GPS are you thinking of ?
Hope you like![]()
we definitely like!
what's the colour scheme going to be like W?
All white, or are you going to play a bit?
Agree re horn and searchlight on the top, would even stick a p/v panel to keep the batteries topped up.
If you decide on fitting something up there, think and organize your routing of cabling! not trivial if you want to do a decent job with no ducts visible on the pilars.
cheers
V.
I just had a look back at the initial posts you made - You have come a long way!
What happened to the Dutton?
Excellent work and postings. I have just read from start to now and I am so inspired by your work rate and attitude. Thanks mate much obliged I'm off to the boat.
Tomorrows job is to seal the timbers a bit more and then finish these eyes.
very good W!
glad to see you changed the rest of the screws holding the sapele to countersunk ones
V.
Probably too late but could you drill two holes vertically downwards through the strake with, say 8mm drill bit and then three fore/aft hacksaw cuts. One to join the holes and two in from outside?
each one of those fender eyes has a big smile underneath ! And deservedly so.
When's the launch party ?
(and I like the mid grey paint on the hull - so different from all the other blue and white jobs.....)
Finally manage to catch up on this thread and boy am I impressed. Makes anything I have done on our various boats look like little more than tinkering! I look forward to following the project through to completion.
it's beginning to shape up; nice work. And all that insulation will make the boat very snug.
I have a feeling that you are adding quite bit of weight, and wonder if it is worth leaving a bit of space in the bilges, plus some reinforcement, in case you need to add a bit of ballast if she is a bit tender. Just in case...![]()
