Broads access
the OP has a seaine s41 with an AD of 12 ft I hardley think he will have a problem with HADDISCOE at 24ft all the others swing, his cruising area will be just the same as coming in via GY, neither is the depth an issue, as suggested lowestoft is accessible at any state of tide and an over night at RNSYC does not require any bridge lift
SIMI you are correct - my mistake ! Carlton railway is 15ft hw
Fred, firstly the OP quite clearly isn't the "everyone" I was referring to and an overnight at the RNSYC isn't even entering the Broads at all, is it? Unsure of the relevance of that.
Even in his 'seaine s41' he still has three bridges, one on a fixed schedule and a lock to negotiate which is a great deal more than two bridges operating as one at GY.
But each to their own.
slowboat 35 you obviously haven't been in a while Haven Bridge was out of action for several months last year trapping boats on either side, major repair works starting this week, and the new third crossing at GY means three bridges to negotiate going forward .
miss a bridge lift at Yarmouth and its a 24hr wait at best, miss one at lowestoft and the next is three hours, with waiting pontoons or a night in RNSYC
Missing GY bridges would be a pain but it's the same 24hr delay if you miss your booking at Oulton lock! Nor can one assume that the Haven bridge is the only one in the system likely to breaking down. Indeed I'd always understood that the ropiest of them all were Somerleyton and the Oulton railway swing bridges. No one can predict which will go next. All you can predict is that one will - and its less likely to be the soon to be revamped GY one!
You've also not mentioned the 3rd crossing at Lowestoft that will probably affect leisure traffic worse than Gt Yarmouth's during build as there is next to no commercial traffic requiring regular passage and both will affect us equally when finished - be you going forward or astern.
What happens with your lock booking if the railway bridge delays you substantially as it must sometimes do when trains are off schedule- do the council functionaries hang around and wait? The only time I saw it in action they were very impatient to clear off back to whatever much better things they clearly had in mind to be doing. Or do you just have to allow a sufficient time- buffer?
There are going to be interesting conflictions at both with regard to simultaneous inbound and outbound traffic requiring to pass both/all bridges. How will they manage that? Double openings fifteen minutes apart? They surely can't have both bridges up for the time it takes to transit between them. Either would be devastating for road traffic.
The "waiting pontoon" at Lowestoft, aka the floating guano storage facility is of hazardous use at low tide (when most sailing boats arrive) if they're over 1,5 m draft unless they want to sit five metres off it and wait for the tide to rise again...and maybe miss the bridge to boot.
Or have they finally got round to dredging it? I was told they never would do that corner as it "wasn't commercial".
As I said earlier, each to their own.
Missing GY bridges would be a pain but it's the same 24hr delay if you miss your booking at Oulton lock! Only if your Lock booking is for 5:00pm. Hence the suggestion of overnighting at the RN&SYC - or, if you want to head through into the inner harbour, there are a number of marinas & boat yards that can accommodate a visiting yacht or two. Not too sure where in Gt. Yarmouth you might find to moor up easily overnight, especially when something made of steel carrying several thousand tonnes of cargo wants to dock rather close during the night. Nor can one assume that the Haven bridge is the only one in the system likely to breaking down. No, but over the last couple of years, it's been a fair bet Indeed I'd always understood that the ropiest of them all were Somerleyton and the Oulton railway swing bridges. Only if the weather gets too hot - and they are working of getting the problems fixed. No one can predict which will go next. All you can predict is that one will - and its less likely to be the soon to be revamped GY one! The Haven Bridge was 'revamped' last year at great expense...
You've also not mentioned the 3rd crossing at Lowestoft that will probably affect leisure traffic worse than Gt Yarmouth's during build as there is next to no commercial traffic requiring regular passage and both will affect us equally when finished - be you going forward or astern. Leisure boats do not generally head under the bridge with commercial traffic - the Harbour Master prefers to keep the two well away from each other, hence the scheduled lifts for small boats. Basically, it will make no difference.
What happens with your lock booking if the railway bridge delays you substantially as it must sometimes do when trains are off schedule- Then the train waits while the boat goes through - the train is already off-schedule. do the council functionaries hang around and wait? They're not Council workers, they are employed by Sentinel Leisure and operate the Lock on behalf of the Broads Authority The only time I saw it in action they were very impatient to clear off back to whatever much better things they clearly had in mind to be doing. Or do you just have to allow a sufficient time- buffer? No, they'll wait if they have a boat scheduled to come through.
There are going to be interesting conflictions at both with regard to simultaneous inbound and outbound traffic requiring to pass both/all bridges. How will they manage that? Double openings fifteen minutes apart? They surely can't have both bridges up for the time it takes to transit between them. Either would be devastating for road traffic. The Bascule & the 3rd Crossing bridges will be timed lifts. The Oulton Bridge is also scheduled to lift specifically to allow boats to travel from one lift to the next. There is not now & will not be simultaneous inbound & outbound traffic through the bridges - another reason for the scheduling.
Or have they finally got round to dredging it? I was told they never would do that corner as it "wasn't commercial". You really don't have to use that pontoon, there is a rather pleasant yacht club directly opposite. Although I didn't have any trouble mooring on the waiting pontoon at low tide the last time I used it, albeit with a mere 1.2 metre draft. There was also a pre-dredge bathymetric survey operation scheduled for Lowestoft Approaches, Inner and Outer Harbour Areas just this week, so it might be getting cleared out.
As I said earlier, each to their own. Indeed, there is a case for using either. However, it's usually preferable to base your opinion on fact or just admit you would choose one over the other just because it 'seems easier', instead of overstating minor timings as major problems.
Not too sure where in Gt. Yarmouth you might find to moor up easily overnight, especially when something made of steel carrying several thousand tonnes of cargo wants to dock rather close during the night. . . .
The (Great Yarmouth) Haven Bridge was 'revamped' last year at great expense...
I am not arguing for one thing or another, but the following may be of help to someone.
Leisure vessels can moor up at the Great Yarmouth Town Quay (on the east side of the river, just below the Haven Bridge, adjacent to the Town Hall and the (green) Lydia Eva steam drifter/trawler). This is not used by large commercial craft (occasionally smaller wind-farm crew vessels moor immediately downstream). Whether this counts as 'easy' is debatable. The quay wall has projecting vertical wooden bulwarks, which without a fender board can be a challenge. There is a significant rise and fall of tide, and lines are likely to need adjusting as it does so, and the tidal current is quite strong there. There are ladders to climb the wall, and rings and bollards to tie to. There is occasional moderate wash from the RIB Lifeboat rushing under the bridge if there's an incident in the Broads, or from motorboats going through/under the bridge against a strong tide. There is, in theory, a charge for using the Town Quay, but I'm not sure anybody ever bothers to collect it. There are no facilities, but there are publicly accessible toilets in the Town Hall during weekday office hours, and the town centre is just a couple of hundred yards away. (There are numerous museums* and interesting attractions (including the Lydia Eva - highly recommended) within a few hundred yards, although the town as a whole is down on its uppers.)
I believe that the previous refurbishment of Haven Bridge was to repair the failing traffic deck, not the lifting mechanism.
I believe Haven Bridge is now operated by Peel Ports, who are now the harbour authority for GY. Bridge lifts have to be booked by the previous working day, office hours only. No booking weekends or bank holidays, but the bridge does lift on such days. It is not limited to one lift per day, and lifts are coordinated with the lifting of Breydon Bridge, just a little further upstream on the River Yare. On a visit a few years ago, having been unaware of the need to book a lift in advance, I was unable to contact GY Harbourmaster's Office by either phone or VHF (this may have been a one off, or have improved since Peel Ports took over the harbour (they're generally more on the ball than their predecessors), but Broads Control (01603 756056, VHF channel 12 or email Broads.control@broads-authority.gov.uk ) knew what bridge lift times had been previously booked.
It will be some years before the new 'Third River Crossing' bridge on the Yare in Great Yarmouth is completed. I believe it is intended there will be waiting pontoons (not connected to the shore) either side of that new bridge.
I believe that the railway bridges over the Broads rivers are operated by Network Rail staff, not the Broads Authority. All those bridges are very old, and so unreliable, and Network Rail are not very interested in making their hugely expensive replacements a priority.
[* Nelson Museum and Elizabethan House Museum just across the road from the Town Quay; Tolhouse Museum (old prison - earliest municipal building in England?) next street away from the river - another 100yds; Time and Tide Museum about 1/4 mile SE from Town Quay; Nelson's Monument, about 1km south of the Town Quay (like the one in Trafalgar Square, but if you check opening times you can climb the 217 steps inside to the top.]
LittleSister I think you are incorrect Haven bridge will lift 7 days a week when not broken down Peel ports get paid a substantial sum to operate the bridge and during the last season have got away with very few lifts
All useful stuff!
I'm under the impression that both new 3rd Crossings will be operational around the same time.
Yes, the Railway bridges are operated by Network Rail and even though the company is trying not to get them properly operational (expensive even if it is older, heavy ironwork tech), they are still under a legal obligation to ensure river traffic can get through.
It's the Lock that's under the remit of the BA, the road bridge is operated on behalf of the council, by Sentinel Leisure employees.
That's what I said!
But bookings (not lifts) will only be taken on weekdays office hours. If you want a lift on a Sunday or Bank Holiday Monday, you need to book it by the previous Friday, during office hours.
From Peel Ports (Great Yarmouth) website - 'Bridge bookings can be made during office hours on 01493 335522. Lifts for weekends should be booked by 16:00 on Friday or on the previous working day in the case of Public Holidays.'
More info here - https://www.peelports.com/media/4198/visiting-small-craft-information-sheet-march2017-1.pdf
By far the easiest (and, imo useful) place to moor in GY is alongside Lydya Eva. Her bulwarks have steel railings above them and the stanchions offer perfect attachments at the ideal height. You couldn't possibly damage her with a yacht!
If doing so they'll much appreciate the (hopefully generous) donation you slip through under the wheelhouse door with a note of thanks.
That way everyone benefits.
A variety of opinions here! ?
My tuppence worth......
We are Broads based and do regular coastal cruises and are very familiar with both Gt Y and Lowestoft access to / from sea. Noting that the OP is coming from the Thames my recommendation would be to aim for Lowestoft and a night at the Royal Norfolk & Suffolk Yacht Club. Access at all states of tide, plenty of visitor moorings, a lovely club house with good beer and food and it takes all the angst out of passage planning to meet a fixed bridge lift time. What’s not to like?
From there it is an easy hop seven miles up the coast to Gt Y for a booked bridge lift or alternatively going in via Mutford Lock. Bascule bridge has plenty of lifts during the day and the lock and rail bridge swing (if required) are easily booked.
An S41 might get under the bridges at Gt Y to head for the northern rivers but only on LW springs would be my guess. They put some timber on the underside of the bridges that reduced the clearance a few years ago. Worth saying that whilst it is nice up there the number of hire boats is significantly higher than the southern rivers and getting bashed into is virtually guaranteed. We haven’t been up there for years for that reason and becasue of the bridge clearance challenges. I would also say that we would never consider a night at Town Quay in Gt Y - moorings not great and nothing between you and the local brigandry.
If staying south then I would say go in via Mutford Lock because there ain’t much between Gt Y and Reedham, which is where you reach the Yare from the Waveney via the New Cut but having had access to a lot more places to stay/see. Perhaps leave via Gt Y with the last night being at Reedham or Berney Arms (noting that it isn’t open so need to be self-sufficient) with another stay at RNSYC before heading south. If time permits a night in Southwold is well worth it - highly recommended in fact. Perhaps better done on the way up as tides might not be favourable when leaving to head south.
I had a boat on the Broads for a couple of seasons. There were some pretty bits, but there were also many problems with hire boats (and their crews). I wouldn't ever want to re-visit.
Hence my comments about never venturing to the Northern rivers - a lot different on the Southern side.
We sail on the Northern rivers, 28' with a 'gret ol' bowsprit. Hire boatstend to keep out of the way by and large :p
There's not a lot on the southern side. We had a season based in Beccles and my wife complained that it was "all going and coming back".
I didn't have a problem with hire boats on the Yare and Waveney - there are far fewer of them there than in the northern rivers (Bure, Thurne, Ant, etc.), as Greg2 points out, and hotspots with big hire-boat yards, like Wroxham, Potter Heigham and Stalham are best avoided on Saturdays (changeover day for many).
It's also a completely different world in the winter: much, much quieter, and with its own desolate charm (provided you have heating on your boat!).
Note that the short term licence fees are very expensive relative to the annual licences. (I get the impression that's because all the RYA and other representatives on the Broads Authority's Navigation Committee are local boat owners or hire-boat company people, and have no interest at all in encouraging additional boats to visit.) A Boat Safety Scheme certificate is required for stays over (IIRC) 2 months.
Sadly, many of the riverside pubs around the Broads are fairly dire, or permanently closed, but there's some better ones within a few minutes walk.
On the plus side there are lots of free moorings: Broads Authority moorings (24 hour max per visit to each of them), and others provided by pubs to customers. There's also some interesting places to visit such as the ruins of St. Benet's Abbey and the Roman Fort at Burgh Castle. I found the Broads Authority's Navigation Rangers, Yacht Station Attendants and Broads Control (info & emergency help via phone or VHF) staff helpful and friendly.
Keeping a boat on the Broads wouldn't be my cup of tea, but I did enjoy visiting by yacht (though I wouldn't make it a habit, I wouldn't rule out going again) and I've enjoyed canoeing there numerous times.
The real beauty of the broads is, as Little Sister said, the solitude which usually means out of season but with a bit of care you can overnight on some of the broads in total solitude year round. There are few finer places to spend a night than the dear old Berney Arms, one of the much loved pubs that the Broads Authority has driven out of business by their rapacious over-charging and insane levels of compliance that have made hire boats so dreadfully expensive. Is it any wonder so few people can afford to spend money in them? I know of few boating spots that match the Berney Arms' solitude, peace and vast vistas. (Except when partying hire-boats wreck the ambiance, it has to be admitted)
I've sea-sailed fairly extensively in a broads-based yacht and found the combination of stimulating day-sailing and easy access to the sea a very enjoyable contrast. Eating a leisurely supper as you motor up the river at dusk to yourmooring after a bositerous bash up from the Orwell is one of life's great pleasures.
But why does the Broads Authority seem so keen to deter visitors with those outrageous short-visit ripoffs oops! taxes? The Dutch in particular would come in numbers if they weren't so savagely striped for the privilege. What a sad, unnecessary own-goal.
And for the racing types be they serious, funsters or just wanna have a go, the Yare Navigation Race is, imho, well on the way to being sailing UK's Isle of Man TT. No, perhaps more like the Targa Florio or the Mille Miglia? Crazy, quirky, highly competitive at even at a fun level and just plain British unique.
