Norman_E
I have an asymmetric cruising chute for my Jeanneau 45.2, which is about 11 tons in sailing trim. The sail has the following dimensions and is of fully radial construction: Luff 14.74m. Leach 12.97m and foot 8.33m. From those figures I think the area must be about 70 sq. metres. With a bowsprit I can do away with the snuffer and fit a top down furler.
What I want to do is make a stainless steel retractable bowsprit which will stick out 600 to 650mm beyond its sliding fixture attached to the bow roller and a greater distance behind the fixture to a deck mounting. The critical strength issue is the bending force applied at the bow roller mounting. Can anyone here guide me as to the size of code 40 or code 10 pipe needed? For various reasons I would ideally like the pipe to be 2.5 inch code 40 which measures 2.875 inches O.D. or smaller. I notice that the Selden aluminium bowsprit requires to be 87mm for an 11.3 ton boat, though I don't know what its wall thickness is and how much stronger stainless steel pipe is compared to aluminium alloy.
I know Southerly supplied some of their boats with a stainless bowsprit. If anyone has one perhaps they could measure it?
