Malcolm3
X
I have a Bowman 48 1993. In 2008 prior to crossing the atlantic I found a crack on the bottom of the forward partition just behind the mast. There were no others. In 2009 in Antigua I found all the floors over the keel had developed cracks where they join the hull. A photo is attached of one but all have.The actual keelbolts are all right as far as can be seen.In a seaway I can feel slight opening and closing of the crracks. Why has this happened ? is it serious ? . I have presumed it relates to sailing in waves although there was a minor bump before we left.
Thanks. I have a surveyor and the boat is now out the water in Antigua but not much wiser. There is no obvious cracking on the outside. It is clear that the frames are seperating from the hull and at the moment we are grinding them back and reglassing. Re the wood do you think there is wood under the keel bolt nuts or do you mean the wood that the frames are made of. The question is whether more needs done and how one would know. Re the keel matrix seperating there is no obvious cracking along the sides - only where the frames are
Malc
The cracks definitely became less when we sat the boat on the keel - no doubt and the rigging tensed up I think - keel stepped mast.
Surveyor advised basically grinding off glass on each side of frame where cracked , removing the keel bolt nutts and adding glass or rather a matt stuff and resin 3 layers over whole flat bit bolts go through and running up the sides of the frames and sides of boat. This is ongoing but still I dont really understand what has happened or really whether this is enough or not.
Malc
Re resin - epoxy has been used in the repair.
Yes it is fixed - or we have papered over the cracks depending on what one feels is wrong. Will of course go for short voyage first but essentially next voyage is about 3,500 miles and very keen not to find out a further problem after first 1500 !. Would be very interested if any other similar boats had developed the same problem and what they did about it.
And how it worked!
Malc
The first crack was certainly at the forward partition between the saloon and forecabin behind the mast step .At that time there were no cracks in any of the other floors but at some time thereafter over a period of 10 months atlantic sailing they developed but not sure when as there are tanks between the floors and it wasnt till the back one developed that we could see it and then found the rest when we removed the tanks. In that 6 months really can only attribute to sailing in big seas as no groundings but as the first crack was already there it is an extension of a problem that had already started.
The big question is whether now we have attached the floors back that solves the problem or whether there is a bigger problem with the whole keel.
Externally the yacht is antifouled and I intend to blast that off and look carefully for cracks externally in the gel goat at the top of the fibreglass keel former where it flanges out to the hull but other than doing that dont know what else can do.
Will also see what happens when relaunch and will bounce it around a bit to see if the cracks return. I have looked carefully externally at the back of the keel and see no problem but cant see the back internally clearly as there is a deep sump - nothing obvious though. The front of the keel at the root had been superficially repaired before by someone - I ground the repair out but no evidence of deeper damage and have just reglassed it over.
I think I think that the floors have just not been well attached in the first place and that we have cured it but not quite certain particularly as this has developed 15yrs after built but it is difficult to know what else to do.
Malc
That looks a really good sound job Clyde Wanderer. I bet that puts a lot of keel reinforcement jobs to shame! I hope Malcom3 ponders this and the fact that you have done this on a 30 footer with a 3 ton keel? No idea what the keel weighs on a bowman 48!
Thanks for replys . Have drilled one hole and it seemed OK will do a couple more but wood appears sound. Applied 3 x FIB-948 24oz fiberglass woven roving with West system epoxy in centre line overlapping 6” outward and over to each application end and throughout bilges and around studs. Also additional strengthening of 3x overlapping
3/4oz e-glass biaxial with west system epoxy to corners, facings, and longitudinal cross beam to hull bond. Certainly the floors are closer on Clyde Wanderer and as you say this keel is heavier. Have attatched photos of what is being done currently. Clyde wanderer when you say you increased the bilge stub was that done on the inside or outside?
